voice source-group - Toll Fraud prevent
I don't have enogh space on my router to upgrade the IOS from 12.xx to 15.xx to prevent Toll Fraud. Can you help me other way to prevent toll fraud.
If voice source-group caan prevent toll fraaud please help me how can i do this .
or give me another idea how can i fix this problem .
Sincerely,
Gezim
Hall of Fame Super Gold
You should upgrade flash and RAM, both are economical.
I'm asking fo voice source-group can or can not prevent Toll Fraud :-) ??
if yess how can i do that ??
Thanks in advance,
Gezim
VIP Super Bronze
Cisco has a document published for toll-fraud prevention prior to 15.1(2):
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a00809dc487.shtml
I don't see how voice source-group is related to toll fraud prevention. Do you have a specific document or example citing an example that it is?
Please remember to rate helpful responses and identify helpful or correct answers.
Re: voice source-group - Toll Fraud prevent
Hi.
I add a tip to what my Buddies suggested ( +5P each )
To avoid tool fraud in IOS release previous 15.1, the recommended actions are:
- configure ip access- list allowing H323 and SIP traffic to authorized ip addresses
- using direct-inward-dial on your incoming pots dial-peers and configuring a specific called number matching your DID.
Here a useful link
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/dialpeer/configuration/12-4t/vd-dp-overview.html#GUID-2ABE5250-0DE4-4E91-B691-395EF4E9008D
Carlo
Please rate all helpful posts "The more you help the more you learn"
322
