Voice translation on ISDN line
Guys,
I look after a CM in a different country & they get lots of overseas calls, but when they get a missed call it comes up with say 944173339xxx, but they can't dial that number back. I have some config in the router to add 90044 to 44, but this doen't hit the phones with the 00 in the number
The international call are coming in over an ISDN 30, so I feel there is no point in adding it to a dial-peer as these are pots.
I have the following config on the router:
voice translation-rule 2
rule 1 /44/ /90044/
rule 2 // /9/
voice translation-profile Prefix_calling/called_numbers
translate calling 2
translate called 1
I have tried to add the translation profile to the se0/0/0:15, but that is not valid.
Angus
1 ACCEPTED SOLUTION
Bronze
Re: Voice translation on ISDN line
Hi Angus,
I think you can achieve by using "Significant digits" & "Prefix DN" features under Digital PRI port on MGCP Gateway configuration in Cisco Callmanager.
Pls find the following link which may help...
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_4/ccmcfg/b06gtway.html#wp1311922
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
I think I may haver fixed it by adding:
voice-port 0/0/0:15
translation-profile incoming Prefix_calling/called_numbers <<< this
cptone IE
I won't be able to tell until the customer get in tomorrow.
Angus
Bronze
Yes Angus.
You need to add to Voice port.
The correct translation rule would be...
rule 1 /^44\(.*\)/ /90044\1/
That's it. Please try this & let me know if it helps...
Regards...
-Ashok.
Hall of Fame Super Gold
Hi, actually the above rule is not optimal, because it works only for calls received from UK only and not for all the others.
So the correct rule is:
rule 1 // /900/ type international international
rule 2 // /9/ type national national
Remember this works only when you're using H.323 and not MGCP.
Would it not be valid to put it under the peer?
dial-peer voice 1000 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
translation-profile incoming xxx
Chad
Yes. However it's easier logic to put translation-profile under voice ports whenever possible.
Beside, incoming pots DP don't need "port". In fact, port command is ininfluent for incoming pots DP.
we are using mgcp and still have the same issue.
So the config I currently have is:
voice translation-rule 1
rule 1 /9100/ /69149/
rule 2 /9200/ /69219/
rule 3 // /6/
rule 2 // /9/
translate calling 2
translate called 1
voice-port 0/0/0:15
cptone IE
dial-peer voice 1 pots
preference 1
direct-inward-dial
port 0/0/0:15
When I put the number through the test it looks fine:
DUB-PTER1-3825-01#test voice translation-rule 2 441733393430
Matched with rule 1
Original number: 441733393430 Translated number: 900441733393430
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
DUB-PTER1-3825-01#
Jun 23 19:04:45.991: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x39B5
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98398
Exclusive, Channel 24
Calling Party Number i = 0x1183, '441733392100'
Plan:ISDN, Type:International
Called Party Number i = 0x81, '9200'
Plan:ISDN, Type:Unknown
Jun 23 19:04:46.063: ISDN Se0/0/0:15 Q931d: srl_send_l3_pak:
If you use MGCP, DP's and translation rules are not applicable. Any configuration must be done on the CM.
Unfortunately I cannot tell you how to configure CM with MGCP because I don't know that myself.
Thanks for all the help, will go to CM now.
Angus
Bronze
Hi Angus,
Regards...
-Ashok.
149
