Showing results forĀ
Search instead forĀ
Did you mean:Ā
Voice translation problem from cell phones
kamounimohamed
I have a Cisco 2811 gateway with a E1 card installed (used with CUCM 6.1), I set up voice translation rules so that i can have direct lines. The problem i have is that when i call from  landline phone it works great the line is redirected to the desired extension but from when i call from a cell phone the call is answered by the router (all that i hear is a tone that lasts for about a minute then hangs up)
When i don't use the translation rules ( i use the "connection plar 900" for ex ) it works with both mobile and land phones.
I have attached the configuration of our gateway the cisco 2811 and the log of the translation from both cell and land phones.
Thanks.
vandana
You Should collect the following debugs to investigate the issue:
debug voice translation
debug isdn q931
debug voip ccapi inout
I've collected the debugs, as i said before: when i don't use the translation rules i can get incoming calls from both cell phones and land phones but when i use the translation rules it only works from land phones.
Aslam Alaykom,
you need to modify incoming pots dial peer as follow
dial-peer voice 3 pots
direct-inward-dial
also remove connection plar from the voice port
Eid Mubarak
AMH
Aslam Alaykom,
Thanks so much it worked.
Aid Moubark
