Voice Translation Problem
I have a problem that seems like it should be pretty simple but I've been banging my head against the wall for a couple days now and still nothing. I'm trying to take a number pattern (7135551[2-4]..) and put a plus in front of it (make it an e.164 number). Consider the output below:
router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
router(config)#voice translation-rule 5
router(cfg-translation-rule)#rule 1 /^(7135551[2-4]..)$/ /+\1/
router(cfg-translation-rule)#end
router#test voice translation-rule 5 7135551212
7135551212 Didn't match with any of rules
router(config)#no voice translation-rule 6
router(config)#voice translation-rule 6
router(cfg-translation-rule)#rule 1 /^(7135551[2-4]..\)$/ /+\1/
% unmatched ()                                     ^
% Invalid input detected at '^' marker.
router(cfg-translation-rule)#rule 1 /^(7135551[2-4]..\$)/ /+\1/
router#test voice translation-rule 6 7135551212
router(cfg-translation-rule)#rule 1 /^1\(7135551[2-4]..\)$/ /+\1/
router#test voice translation-rule 6 17135551212
Matched with rule 1
Original number: 17135551212    Translated number: +7135551212
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Can anyone tell me why I'd be getting the results I'm getting? This is CME 8.5
1 ACCEPTED SOLUTION
Re: Voice Translation Problem
For this rule
And this test
You got
Because
Your test string of "7135551212" does not contain parenthesis "(" ")" as your pattern "/^(7135551[2-4]..)$/" is looking for.
To fix
Change your pattern to "/^\(7135551[2-4]..\)$/", which is how you group matches for recalling later
For this rule
You got
% unmatched ()
Because
You only escaped one of the parenthesis, therefore you have one literal "(" and one grouping "\)", neither of which have their required partner.
To fix
For this rule
And this test
You got
Because
Your input string "7135551212" does not contain parenthesis "(" ")", nor a dollar sign "$", as your pattern "/^(7135551[2-4]..\$)/" is looking for
To fix
Change your pattern to "/^\(7135551[2-4]..\)$/", which is how you group matches for recalling later, and how you use the "end of line" special character "$"
For this rule
And this test
You got
Matched with rule 1
Because
Your input string "17135551212" matches your pattern "/^1\(7135551[2-4]..\)$/" exactly, and the result was to write out a plus sign "+" followed by the match in group 1 "7135551212"
To fix
Change your pattern to "/^\(7135551[2-4]..\)$/", because it doesn't look like you actually needed to match on the leading "1"
If you simply wanted to prefix:
All numbers
rule 1 // /+/
Some numbers in a range
rule 1 /^7135551[2-4]..$/ /+\0/
A specific number
rule 1 /^7135551212$/ /+\0/
Note my use of the "\0" and the absence of parethesis grouping in the match pattern.  This is a cleaner and more effecient way than grouping, and recalling "\1", because it happens automatically, and you create no additional overhead.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
the second part of the rule is /+/
For this rule
And this test
You got
Because
To fix
For this rule
You got
% unmatched ()
Because
To fix
For this rule
And this test
You got
Because
To fix
For this rule
And this test
You got
Matched with rule 1
Because
To fix
All numbers
rule 1 // /+/
A specific number
Anthony Holloway
You sir, rock!
Thank you!  And thanks for the rating!  Good luck to you.
Anthony Holloway
798
