voice translation profil under SRST
Hi Group, I am trying to setup translation profile in SRST mode for branch office to solve issue relate to CUEAC, but encounter some problems,  details as following:
  • In CUCM environment, Inbound call to 988 6600 -> voice gateway -  translate to 6600 -> send to CUCM -> match translation-pattern forward to 8000 - 8000 is a route point and forward to CUEAC -- overflow to 2222 (operator ip phone)
  • In SRST,  Inbound call to 988 6600 -> voice gateway – translate to 6600 -> send to phone in SRST mode --  no DN  match,  only 2222 (operator IP phone)  called dropped.
Try to solve the issue, following translation profile created.
Voice translation-rule 8
Rule 1 /6600$/ /2222/
Voice translation-profile SRST2CUEAC
Translate called 8          (or translate redirect-called 8)
Call-manager-fallback
Translation-profile out SRST2CUEAC
Tested with above setting, failed:  In SRST,  Inbound call to 988 6600 -> voice gateway – translate to 6600 -> failed
seem to me inbound call did not reach to stage where it can match the translation profile, disconnection cause code = 38. Any suggestion ?  cheers Roy
VIP Super Bronze
Can you send a debug voip ccapi inout and a debug isdn q931 ( I am assuming you are using ISDN) while the router is in SRST?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
H aokanlawon,  please see result for deb voip cc inout,   (from deb isdn q931, I can see the call has been sent out via one of dial-peer .T)
000978: .Nov 27 06:03:51: //-1/77F541238028/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=88883002
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=6600
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
000979: .Nov 27 06:03:51: //-1/77F541238028/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22CB8598, Call Info(
   Calling Number=88883002,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=6600(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
000980: .Nov 27 06:03:51: //-1/77F541238028/CCAPI/ccCheckClipClir:
   In: Calling Number=88883002(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
000981: .Nov 27 06:03:51: //-1/77F541238028/CCAPI/ccCheckClipClir:
   Out: Calling Number=88883002(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
000982: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000983: .Nov 27 06:03:51: :cc_get_feature_vsa malloc success
000984: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000985: .Nov 27 06:03:51: cc_get_feature_vsa count is 1
000986: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000987: .Nov 27 06:03:51: :FEATURE_VSA attributes are: feature_name:0,feature_time:554312960,feature_id:182
000988: .Nov 27 06:03:51: //149/77F541238028/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=88883002(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=6600(TON=Unknown, NPI=ISDN))
000989: .Nov 27 06:03:51: //149/77F541238028/CCAPI/cc_process_call_setup_ind:
   Event=0x3D1749B0
000990: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6600
000991: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCallSetContext:
   Context=0x3A720D34
000992: .Nov 27 06:03:51: //149/77F541238028/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 149 with tag 1 to app "_ManagedAppProcess_Default"
000993: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
000994: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=12, Params=0x3A72EE54, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
000995: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCheckClipClir:
000996: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCheckClipClir:
000997: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Destination Pattern=790....$, Called Number=6600, Digit Strip=FALSE
000998: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=77F54123-561D-11E3-8028-78DA6E338A60, Outgoing Dial-peer=12
000999: .Nov 27 06:03:51: //149/77F541238028/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=88883002
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=6600
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
001000: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3CF323A0, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=88883002,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=6600(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=12, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
001001: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001002: .Nov 27 06:03:51: :cc_get_feature_vsa malloc success
001003: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001004: .Nov 27 06:03:51: cc_get_feature_vsa count is 2
001005: .Nov 27 06:03:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001006: .Nov 27 06:03:51: :FEATURE_VSA attributes are: feature_name:0,feature_time:554311168,feature_id:183
001007: .Nov 27 06:03:51: //150/77F541238028/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
001008: .Nov 27 06:03:51: //150/77F541238028/CCAPI/ccCallSetContext:
   Context=0x3A72EE04
001009: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccSaveDialpeerTag:
001010: .Nov 27 06:03:51: //150/77F541238028/CCAPI/ccGetMediaClassTag:
   media class tag 0
001011: .Nov 27 06:03:51: //150/77F541238028/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
001012: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccSetMediaclassIp2ipTags:
001013: .Nov 27 06:03:51: //150/77F541238028/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
001014: .Nov 27 06:03:51: //149/77F541238028/CCAPI/ccGet_xc_nr_asp_info:
001015: .Nov 27 06:03:54: //150/77F541238028/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x3CF323A0, Call Id=150
001016: .Nov 27 06:03:54: //150/77F541238028/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
001017: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
001018: .Nov 27 06:03:54: //150/77F541238028/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=150
001019: .Nov 27 06:03:54: //150/77F541238028/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
001020: .Nov 27 06:03:54: //150/77F541238028/CCAPI/ccCallDisconnect:
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
001021: .Nov 27 06:03:54: //150/77F541238028/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
001022: .Nov 27 06:03:54: //150/77F541238028/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CF323A0, Tag=0x0, Call Id=150,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
001023: .Nov 27 06:03:54: //150/77F541238028/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
001024: .Nov 27 06:03:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001025: .Nov 27 06:03:54: :cc_free_feature_vsa freeing 210A1DF8
001026: .Nov 27 06:03:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001027: .Nov 27 06:03:54: vsacount in free is 1
001028: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=11, Params=0x3A728824, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
001029: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccCheckClipClir:
001030: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccCheckClipClir:
001031: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccCallSetupRequest:
001032: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Guid=77F54123-561D-11E3-8028-78DA6E338A60, Outgoing Dial-peer=11
001033: .Nov 27 06:03:54: //149/77F541238028/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=88883002
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=6600
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
001034: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
001035: .Nov 27 06:03:54: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001036: .Nov 27 06:03:54: :cc_get_feature_vsa malloc success
001037: .Nov 27 06:03:54: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001038: .Nov 27 06:03:54: cc_get_feature_vsa count is 2
001039: .Nov 27 06:03:54: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001040: .Nov 27 06:03:54: :FEATURE_VSA attributes are: feature_name:0,feature_time:554311168,feature_id:184
001041: .Nov 27 06:03:54: //151/77F541238028/CCAPI/ccIFCallSetupRequestPrivate:
001042: .Nov 27 06:03:54: //151/77F541238028/CCAPI/ccCallSetContext:
   Context=0x3A7287D4
001043: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccSaveDialpeerTag:
001044: .Nov 27 06:03:54: //151/77F541238028/CCAPI/ccGetMediaClassTag:
   media class tag 0
001045: .Nov 27 06:03:54: //151/77F541238028/CCAPI/ccSetMediaclassIp2ipTags:
001046: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccSetMediaclassIp2ipTags:
001047: .Nov 27 06:03:54: //151/77F541238028/CCAPI/ccGet_xc_nr_asp_info:
001048: .Nov 27 06:03:54: //149/77F541238028/CCAPI/ccGet_xc_nr_asp_info:
001049: .Nov 27 06:03:57: //151/77F541238028/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x3CF323A0, Call Id=151
001050: .Nov 27 06:03:57: //151/77F541238028/CCAPI/cc_api_call_disconnected:
001051: .Nov 27 06:03:57: //149/77F541238028/CCAPI/ccCallReleaseResources:
001052: .Nov 27 06:03:57: //151/77F541238028/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=151
001053: .Nov 27 06:03:57: //151/77F541238028/CCAPI/ccCallDisconnect:
001054: .Nov 27 06:03:57: //151/77F541238028/CCAPI/ccCallDisconnect:
001055: .Nov 27 06:03:57: //151/77F541238028/CCAPI/cc_api_get_transfer_info:
001056: .Nov 27 06:03:57: //151/77F541238028/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CF323A0, Tag=0x0, Call Id=151,
001057: .Nov 27 06:03:57: //151/77F541238028/CCAPI/cc_api_call_disconnect_done:
001058: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001059: .Nov 27 06:03:57: :cc_free_feature_vsa freeing 210A1DF8
001060: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001061: .Nov 27 06:03:57: vsacount in free is 1
001062: .Nov 27 06:03:57: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2, Params=0x3A732BA4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
001063: .Nov 27 06:03:57: //149/77F541238028/CCAPI/ccCheckClipClir:
001064: .Nov 27 06:03:57: //149/77F541238028/CCAPI/ccCheckClipClir:
001065: .Nov 27 06:03:57: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=6600, Digit Strip=TRUE
001066: .Nov 27 06:03:57: //149/77F541238028/CCAPI/ccCallSetupRequest:
   Guid=77F5082: .Nov 27 06:03:57: //-1/7B91EFAC8029/CCAPI/ccCheckClipClir:
001083: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001084: .Nov 27 06:03:57: :cc_get_feature_vsa malloc success
001085: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001086: .Nov 27 06:03:57: cc_get_feature_vsa count is 3
001087: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001088: .Nov 27 06:03:57: :FEATURE_VSA attributes are: feature_name:0,feature_time:554312736,feature_id:186
001089: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
001090: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/cc_process_call_setup_ind:
   Event=0x3D1749B0
001091: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
001092: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCallSetContext:
   Context=0x3A729C44
001093: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 153 with tag 1 to app "_ManagedAppProcess_Default"
001094: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCallProceeding:
001095: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=12, Params=0x3A71F914, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
001096: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCheckClipClir:
001097: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCheckClipClir:
001098: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCallSetupRequest:
001099: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccCallSetupRequest:
   Guid=7B91EFAC-561D-11E3-8029-78DA6E338A60, Outgoing Dial-peer=12
001100: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=88883002
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
dest=6600
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
001101: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccIFCallSetupRequestPrivate:
001102: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001103: .Nov 27 06:03:57: :cc_get_feature_vsa malloc success
001104: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001105: .Nov 27 06:03:57: cc_get_feature_vsa count is 4
001106: .Nov 27 06:03:57: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001107: .Nov 27 06:03:57: :FEATURE_VSA attributes are: feature_name:0,feature_time:554310720,feature_id:187
001108: .Nov 27 06:03:57: //154/7B91EFAC8029/CCAPI/ccIFCallSetupRequestPrivate:
001109: .Nov 27 06:03:57: //154/7B91EFAC8029/CCAPI/ccCallSetContext:
   Context=0x3A71F8C4
001110: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccSaveDialpeerTag:
001111: .Nov 27 06:03:57: //154/7B91EFAC8029/CCAPI/ccGetMediaClassTag:
   media class tag 0
001112: .Nov 27 06:03:57: //154/7B91EFAC8029/CCAPI/ccSetMediaclassIp2ipTags:
001113: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccSetMediaclassIp2ipTags:
001114: .Nov 27 06:03:57: //154/7B91EFAC8029/CCAPI/ccGet_xc_nr_asp_info:
001115: .Nov 27 06:03:57: //153/7B91EFAC8029/CCAPI/ccGet_xc_nr_asp_info:
001116: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x3CF323A0, Call Id=154
001117: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/cc_api_call_disconnected:
001118: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccCallReleaseResources:
001119: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=154
001120: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/ccCallDisconnect:
001121: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/ccCallDisconnect:
001122: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/cc_api_get_transfer_info:
001123: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CF323A0, Tag=0x0, Call Id=154,
001124: .Nov 27 06:04:00: //154/7B91EFAC8029/CCAPI/cc_api_call_disconnect_done:
001125: .Nov 27 06:04:00: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001126: .Nov 27 06:04:00: :cc_free_feature_vsa freeing 210A1C38
001127: .Nov 27 06:04:00: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001128: .Nov 27 06:04:00: vsacount in free is 3
001129: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=11, Params=0x3A7302C4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
001130: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccCheckClipClir:
001131: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccCheckClipClir:
001132: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccCallSetupRequest:
001133: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccCallSetupRequest:
   Guid=7B91EFAC-561D-11E3-8029-78DA6E338A60, Outgoing Dial-peer=11
001134: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=88883002
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=6600
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
001135: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccIFCallSetupRequestPrivate:
001136: .Nov 27 06:04:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001137: .Nov 27 06:04:00: :cc_get_feature_vsa malloc success
001138: .Nov 27 06:04:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001139: .Nov 27 06:04:00: cc_get_feature_vsa count is 4
001140: .Nov 27 06:04:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001141: .Nov 27 06:04:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:554310720,feature_id:188
001142: .Nov 27 06:04:00: //155/7B91EFAC8029/CCAPI/ccIFCallSetupRequestPrivate:
001143: .Nov 27 06:04:00: //155/7B91EFAC8029/CCAPI/ccCallSetContext:
   Context=0x3A730274
001144: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccSaveDialpeerTag:
001145: .Nov 27 06:04:00: //155/7B91EFAC8029/CCAPI/ccGetMediaClassTag:
   media class tag 0
001146: .Nov 27 06:04:00: //155/7B91EFAC8029/CCAPI/ccSetMediaclassIp2ipTags:
001147: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccSetMediaclassIp2ipTags:
001148: .Nov 27 06:04:00: //155/7B91EFAC8029/CCAPI/ccGet_xc_nr_asp_info:
001149: .Nov 27 06:04:00: //153/7B91EFAC8029/CCAPI/ccGet_xc_nr_asp_info:
001150: .Nov 27 06:04:01: //149/77F541238028/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x22CB8598, Call Id=149
001151: .Nov 27 06:04:01: //149/77F541238028/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=FALSE, Cause Value=102, Retry Count=0)
001152: .Nov 27 06:04:01: //152/77F541238028/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
001153: .Nov 27 06:04:01: //152/77F541238028/CCAPI/ccCallDisconnect:
   Cause Value=102, Call Entry(Responsed=FALSE, Cause Value=102)
001154: .Nov 27 06:04:01: //152/77F541238028/CCAPI/cc_api_get_transfer_info:
001155: .Nov 27 06:04:01: //149/77F541238028/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
001156: .Nov 27 06:04:01: //149/77F541238028/CCAPI/ccCallDisconnect:
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
001157: .Nov 27 06:04:01: //149/77F541238028/CCAPI/cc_api_get_transfer_info:
001158: .Nov 27 06:04:01: //149/77F541238028/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22CB8598, Tag=0x0, Call Id=149,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
001159: .Nov 27 06:04:01: //149/77F541238028/CCAPI/cc_api_call_disconnect_done:
001160: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001161: .Nov 27 06:04:01: :cc_free_feature_vsa freeing 210A24F8
001162: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001163: .Nov 27 06:04:01: vsacount in free is 3
001164: .Nov 27 06:04:01: //152/77F541238028/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22CB8598, Tag=0x0, Call Id=152,
001165: .Nov 27 06:04:01: //152/77F541238028/CCAPI/cc_api_call_disconnect_done:
001166: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001167: .Nov 27 06:04:01: :cc_free_feature_vsa freeing 210A1DF8
001168: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001169: .Nov 27 06:04:01: vsacount in free is 2
001170: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x22CB8598, Call Id=153
001171: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/cc_api_call_disconnected:
001172: .Nov 27 06:04:01: //155/7B91EFAC8029/CCAPI/ccCallDisconnect:
001173: .Nov 27 06:04:01: //155/7B91EFAC8029/CCAPI/ccCallDisconnect:
001174: .Nov 27 06:04:01: //155/7B91EFAC8029/CCAPI/cc_api_get_transfer_info:
001175: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/ccCallDisconnect:
001176: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/ccCallDisconnect:
001177: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/cc_api_get_transfer_info:
001178: .Nov 27 06:04:01: //155/7B91EFAC8029/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CF323A0, Tag=0x0, Call Id=155,
001179: .Nov 27 06:04:01: //155/7B91EFAC8029/CCAPI/cc_api_call_disconnect_done:
001180: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001181: .Nov 27 06:04:01: :cc_free_feature_vsa freeing 210A1C38
001182: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001183: .Nov 27 06:04:01: vsacount in free is 1
001184: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22CB8598, Tag=0x0, Call Id=153,
001185: .Nov 27 06:04:01: //153/7B91EFAC8029/CCAPI/cc_api_call_disconnect_done:
001186: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001187: .Nov 27 06:04:01: :cc_free_feature_vsa freeing 210A2418
001188: .Nov 27 06:04:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001189: .Nov 27 06:04:01: vsacount in free is 0
001190: .Nov 27 06:07:01: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   remove it from the queue
VIP Super Bronze
From the logs, you can see that the call has not been xlated from 6600 to 2222. Can you please attach your sh run..You can also change the direction fo your translation profile under call-manager-fallback to IN
Translation-profile IN SRST2CUEAC
Hi Aokanlawon, you are right the call did not reach to the stage where get chance to match the translation-profile, this is the problem.
I do have translation profile under SRST set as IN, it works fine. IN is from IP Phone to Router, while in this situation, it is from router to IP phone, which shuld be out. Anyway, I removed the existing IN Translation-profile and add the SRST2CUEAC set IN, and it did not work.
Now the question is why the 6600 did not match the translation-profile setup in the SRST, is there any other command we can use here to force it to go through the translation-profil before senting it via dial-peer?  Cheers Roy
VIP Super Bronze
What you should do is this..
1. configure a new dial-peer tomatch the destination-pattern 6600
2. give it a lower preference value, so that in norml operation calls will go to cucm
3. apply the xlation profile to that dial-peer
eg..
dial-peer voice 100 voip
preference 5
session-target ipv4:XXXXXX, (where xxxx= ip address of your srst router or loopback interface on that router if you have one)
Translation-profile OUT SRST2CUEAC
no vad
dtmf-relay h245-alpha
The reason the translation profile isnt working is because the translation profile under call-manager-fallback will be apllied to the pseudo dial-peers that are created for your ephones in SRST. Since this call doesnt match any ephone, it wont get applied..
thanks Aokanlawon,  tried again and it did not match the newly created DP with the highest perefence in SRST mode. end up I have to ceate 6600 DN in the operator's phone and assign to an isoliated Partition, when it fall over to SRST in present as an extra dn.  Cheers   Roy
311
