Community Member
Voice translation profiles match called number then manipulate calling numb
Hi There,
I'm using Cisco 2821 GW With H323 on the voip side and ISDN E1 to PSTN.
I would like to hide or change the calling number when dialing a specific prefix to PSTN. This is for users who do not want to show there extension number out to PSTN.
I can not see how to match a called number and manipulate the calling number?
Does anyone have a solution for this on the gateway?
Best Regards
/Andreas Ekstrom
1 ACCEPTED SOLUTION
Community Member
Re: Voice translation profiles match called number then manipula
When you dial 9983 inbound dialpeer 201 should be matched ,Then translation applied
and outbound dialpeer matched!
It could work out!
Let me know if it does !
Community Member
i did't understand where You must act(call manager or gateway)
Community Member
In this solution we are using a 3rd party IP-Pbx.
I would like to do this in the gateway with translation-rules but I can not see how to do it.
Andreas
Community Member
Andreas,
When we've done this in the past, we've had the users dial *67 as a prefix to the number to invoke this feature. So you could do something like this...
voice translation-rule 1
rule 1 /.*/ //
voice translation-profile BlockCLID
translate calling 1
dial-peer voice 100 pots
destination-pattern 9*67[2-9]......
port 0/0/0:23
direct-inward-dial
translation-profile outgoing BlockCLID
Also...if you have a CallManager involved, this becomes a lot easier and the gateway config is not necessary. From your description, however, I'm inferring that you have a gateway only solution.
Hope this helps!
Community Member
In your example you have a dedicated PSTN connection for blocking CLID and match on the destination-pattern in that dial-peer and then remove the CLID with a translation-profile.
In my case we are using this dial-peer for all external calls and would like to show the CLID for all calls except the ones dialing this special prefix to hide it. I can not see how to separate the calls in the same dial-peer.
/Andreas
Community Member
You can act on the inbound dial-peer using answer-address [calling number] and then manipulate these calls!
Community Member
Here are my voip dial-peer.
dial-peer voice 200 voip
destination-pattern ....
voice-class codec 1
voice-class h323 1
session target ipv4:x.x.x.x
incoming called-number 0T
dtmf-relay h245-alphanumeric
no vad
So could i create another dial-peer without a destination-pattern to the same IP? and specify in incoming called-number my prefix to hide the CLID?
Something like this?
dial-peer voice 201 voip
translation-profile outgoing noCLID
voice-class codec 1
voice-class h323 1
incoming called-number 9983T
no vad
voice translation-rule 5
rule 1 /.../ /0000/ plan any private
voice translation-profile noCLID
translate calling 5
So in this case will the router check the called number from the same IP for 0T or 9983T and then send that call through the right dial-peer?
Anyway I will do some testing on this.
/Andreas
Silver
Edit your Post and omit the IP addresses as they are public IPs.
Community Member
It could work out!
Community Member
Yes it works. :)
With "debug voice dialpeer" I can see that incoming dial-peer 201 is matched with prefix 9983 and dial-peer 200 for others numbers..
Best Regards
/Andreas
473
