Community Member
voice translation rule characters
Is there any way to use characters other than those that follow e.164 for voice translation rules? Specifically I would like to use the M character.
Hall of Fame Super Gold
Re: voice translation rule characters
There is no way. Although sometime non-standard formatting like ()- is seen in numbers, Cisco doesn't support that.
If you're using SIP this is possible. You can do some SIP header modification that will translate almost anything in the SIP header. So, if you change your GW configuration over to SIP, you will be able to do outbound header translation (not inbound).
Thought this might help.
-nick
153
