Voice Translation Rule Issue
Dear All,
i m running cme 7.1
I need to configure voice translation rule in such a way that
if the user press digit 2 it should get an outside dial tone and will be able to make an outside call.
i configured rule as below
voice translation-rule 2739025
rule 2 /^2/ /19/
voice translation-profile DirectLine1
translate called 2739025
And my dial peer is :
dial-peer voice 99999 voip
translation-profile incoming DirectLine1
answer-address 2739025
dial-peer voice 9999 pots
destination-pattern 19T
port 0/3/0
As per my configuration when i press 2 and make an outside call the gateway gives me a fast busy tone.
but when dial 19 and outside number the call goes fine.
It seems that i am not configuring voice translation rule properly, can you please guide me how i can fix this issue.
Your consideration in this regard will be highly be comendable.
Best Regards,
Malik.
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Malik,
You typically do not create translation rules for such a purpose. All you need is matching dial peers and telephony-service configuration.
So, build dial-peers that match your possible routes, i.e.
dial-peer voice 1 voip
destination-pattern 2T (2 is exclusively matched so it will be stripped)
port 0/3/0
then under your telephone-service configuration add secondary-dialtone 2 to provide dial tone after user presses 2.
HTH,
Chris
You will need to build cor-lists for that.
Here is a good doc on how to do that, it is also described well in CME admin guide as well as many other threads on this forum:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
HTH,
Chris
Malik,
port 0/3/0
HTH,
Chris
Chris,
Many thanks and great idea
i really appreciate your reponse.
i will confgure it accordingly and will get back you.
many thanks
Malik
Hi Chris,
Yes  it worked thank you sooooooo much
really grateful to you
thanks a lotttt man
You're welcome, glad it worked for you, and thank you for nice rating.
Chris
Re: Voice Translation Rule Issue
Dear Chris,
You deserve this rating and i appreciate your effort.
Chris after configuring this i come up with another issue.
The thing that i want each user to use a specific port to make an outside call which in my case is not happening.
Using 2T as a destination pattern i am able to make an outside call but the CME router is picking a random port for making an outside call. (Mapping Outbound calls to Unique FXO Port concept)
How can i restrict the user to use a specific FXO port to make an outside call.
Please let me know how i can fix this issue.
I will be very grateful to you.
Please help me in this issue.
I have attached the current show run for my cme after i did the modification explained by you.
Mukarram
HTH,
Chris
Chris thanks a lott
730
