Voice Translation rule query
Can voice translation rules be configured on both MGCP & H.323 gateways? Or is there some protocol-based restriction?
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: Voice Translation rule query
Nope. MGCP uses centralized dial-plan which all resides in CCM.
You do not use Dial-peers with MGCP
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Silver
As above, dial-peers won't work on an MGCP gateway as all call intelligence resides on the callmanager in this setup. If you're MGCP gateway is configured for SRST then yes you'll dial-peers.
Thanks a lot Darren. This is what was puzzling me. I had seen dial-peers on an MGCP gateway once. Now I do recall that the router was configured for SRST too.
Have a nice day.
Ashok.
VIP Super Bronze
Its not going to work on MGCP. Because MGCP pots ports in under callmanager control, any rule defined is ignored. So you can only use it with H.323.
HTH, pls rate useful posts
Thanks Deji,
On more query. Can you configure dial-peers on MGCP gateways ?
Ashok.
VIP Super Bronze
Silver
141
