voice translation rule to match on *
I would need to have a voice translation rule that matches on *0
Example, the dialed number is *0021234567
The translation should remove the *0 so the result should be 021234567
Any help on how to achieve this would be appreciated.
Kind Regards,
Jeroen
1 ACCEPTED SOLUTION
Re: voice translation rule to match on *
I thought it was \* so it would look like:
rule 1 /^\*0/ //
voice translation-rule 1
rule 1 /^0/ //
All calls begins with 0 (zero) will be change
Example:
002112345 -> 02112345
098765 -> 98765
Att
Peterson
Thanks for your reply
We really need to translate a number that starts with the character *
Jeroen
rule 1 /^\*0/ //
Thanks, that's exaclty what I was looking for.
Rgds,
Jeroen
121
