09-20-2010 12:31 AM - edited 03-16-2019 12:51 AM
Hi all,
I have ccme 7.0.
Below are the debug isdn q931 logs for an ip phone where call forward all is enable on ip phone (having DID 17383831) to 33381821.
can any body tell me how to replace the calling party number 39583729 which is mentioned in bold to 17383831.
I tried to create translation rule, but its not working ....
CCME#
Sep 19 15:04:50.659: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x2D94
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18385
Preferred, Channel 5
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2183, '39583729'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '17383831'
Plan:ISDN, Type:Subscriber(local)
Sep 19 15:04:50.659: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0xAD94 call
ID = 0x0606 switch = primary-net5 interface = User
Sep 19 15:04:50.679: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xA
D94
Channel ID i = 0xA98385
Exclusive, Channel 5
Sep 19 15:04:50.687: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x2 0x1, Calling num 39583729
Sep 19 15:04:50.687: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0861 callI
D = 0x87E2 switch = primary-net5 interface = User
BIPA-CCME#
Sep 19 15:04:50.691: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0861
Sending Complete
Standard = CCITT
Channel ID i = 0xA9838A
Exclusive, Channel 10
Called Party Number i = 0xC1, '33381821'
Sep 19 15:04:50.767: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8
861
Sep 19 15:04:56.835: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x88
61
Progress Ind i = 0x8282 - Destination address is non-ISDN
Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep 19 15:04:56.843: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xAD
94
Sep 19 15:05:02.623: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x
8861
Cause i = 0x8091 - User busy
Sep 19 15:05:02.627: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x086
Sep 19 15:05:02.735: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x8861
Sep 19 15:05:02.743: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x
AD94
Sep 19 15:05:02.823: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x2D9
Sep 19 15:05:02.823: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0xAD94
CCME#
CCME#
can any body help me urgently please
09-20-2010 07:50 AM
Translation probably isn't working because you're matching a different inbound dial-peer than you expect.
Can you get:
sh run
Along with these debugs for the call:
debug voip ccapi inout
debug isdn q931
Something like this should work:
voice translation-rule 1
rule 1 /^39583729$/ /17383831/
voice translation-profile ani
translate calling 1
dial-peer voice 10 pots
incoming called-number 39583729
port 0/0/0:15
translation-profile in ani
09-20-2010 11:56 PM
09-21-2010 06:12 AM
FYI, always run voice debugs at the same time. Running them separate doesn't show how they talk to each other.
Did you takje a look at the output before you send the debugs off? What dial-peers did you see that you are matching inbound and outbound for a call? Do you have translation profiles applied to those peers in the applicable direction?
You have a simple misconfiguration, and I've already alluded to the answer and proper configuration in my previous post. I have faith that you can cross the last gap and figure it out from here on your own.
Familiarize yourself with these links:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
-Steve
