Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Voice translation-rule
Hi, I'm somewhat new with the voice translation-rules, and could use some help.
I'm trying to translate my incomming nummer from a BRI interface ( 503648200 to 503648299 ) to 200 to 299
So this is what i have done :
dial-peer voice 1 pots
description ** BRI pots dial-peer **
incoming called-number 503648...
direct-inward-dial
port 0/0/0
And
voice translation-rule 10
rule 1 /^503648/ //
And
ephone-dn 1 dual-line
number 200
hold-alert 30 originator
One way or the other, if i dial the number it does not work,
But if I use :
number 200 secondary 503648200
It does work.
Why doesn't the translation rule work, am I forgetting something ?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Voice translation-rule
Hi, with translation-rule, you also need to configure a translation-profile and apply it to either DP or voice-port:
voice translation-profile make-did
translate called 10
voice-port 0/0/0
translation-profile incoming make-did
Please rate post if it helps!
translate called 10
voice-port 0/0/0
thanks got me allmost there, i needed to place it on the dial-peer.
But no i've got another challange, my incomming numbers are truncated, I'm lossing the leading 0.
Do I need another translation rule for this ?
Most of the time, placing on voice-port is fine also. All your incoming called numbers will become 2xx and that makes everything easier.
To see what you have to translate, check "debug isdn q931" with "term mon".
You can also use "test voice translation-rule".
Thanks for the appreciation and good luck!
solved it with :
rule 1 /^503648/ //
voice translation-rule 20
rule 1 // /0/
voice translation-profile FromPstn
translate calling 20
translate called 10
Thanks again for your help !
Note rule 10 is likely to not be correct when you receive an international call. It should be then:
rule 1 // /0/ type national national
rule 2 // /00/ type international international
694
