Voice Translation rule
Hi, everyone
well i encountered a gateway config with some voice translation rule which are configured but not used within any profiles or anything they just exist for what reason they could?????
here they are:
voice translation-rule 1
 rule 1 /\(^........$\)/ /00\1/
 rule 2 /\(^.........$\)/ /00\1/
 rule 3 /\(^..........$\)/ /000\1/
 rule 4 /\(^...........$\)/ /000\1/
 rule 5 /\(^............$\)/ /000\1/
 rule 6 /\(^.............$\)/ /000\1/
 rule 7 /\(^..............$\)/ /000\1/
 rule 8 /\(^...............$\)/ /000\1/
voice translation-rule 2
 rule 1 /.200/ /00/
 rule 2 /./ /000/
Thank you.
If voice translation-rule is
If voice translation-rule is not mapped to any translation-profile and further its not applied to Dial-peer then there is no use of it.
Manish
Thanks manish, so there
Thanks manish, so there useless :)
Yes .. but make sure its not
Yes .. but make sure its not mapped or applied to any where.
don't worry i check like
don't worry i check like million time i even Ctrl+F there number it only appears where they are configured at the top , no where in a voice port or a dial-peer
78
