voice translation-rules, 15 limit
Is it possible to have more then 15 translation rules per rule or is there a way to nest them via profiles? Basically I am running into an issue were I have a set of internal extensions that need to be translated to their external DID numbers and ISDN plan before the carrier will allow the numbers outbound; the problem is I have more then 15 numbers that need translation and can only make 15 rules. I might be looking at this the wrong way any insight would be appreciated.
Hall of Fame Super Gold
Re: voice translation-rules, 15 limit
You cannot have more than 15 rules.
Usually internal extensions use the last digits of the full number, eg ext. 3456 maps to 650-555-3456, that is not you case ?
Hall of Fame Super Silver
My suggestion is to use "num-exp" instead.
HTH,
Chris
Thank you for the suggestion; I am not familiar with this command so I will need to do some research.
can you make an example of you extension numbers and assigned DID block ? it seems very strange to me that you cannot define a single rule to make the necessary changes.
It may be possible but I am not well versed in this topic. Essentially I have about 20 DID's that I need to make appear as themselves when presented to the CO switch under the ISDN plan; The DID's are assigned as secondary numbers on the ephone-dn's for the CME router and the primary DN's are in the 80000 range. I need to be able to translate the 80000 to the corresponding DID number to be passed to the CO. I managed to do this with the translate rule but there is a limit of 15 and I need more. Example below.
80000 -> 5555553060
80001 -> 5555553061
80002 -> 5555553062 and so on.
OK, so assuming that you also want:
80010 -> 5555553070
80019 -> 5555553079
the translation-rule would be:
voice translation-rule 800
rule 1 /8000/ /555555306/
rule 2 /8001/ /555555307/
You can also apply a specular translation rule to the incoming calls and avoid use of secondary DNs altogether. Please see:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
I think also num-exp would work, but translation rules are more powerful so that is what I personally use.
I used this before; this is were I was asking about the 15 rule limit; I have upwards of 60 total DID's that need to be translated outbound. I want to avoid assigning the DID's directly to the phone line but from what I am reading this is looking to not be possible.
I'm not sure if you have read the configuration correctly, it uses 2 rules for 20 extensions using the example numbers you mentioned, using the same scheme for 60 numbers that would use 6 rules.
I am not sure I understand your response and I apoligize; but based off of what was written the two rules would only translate one-to-one and I would still run into the 15 rule limit for the voice translation.
No problem. What the rule does is to replace the first 4 digits of an '8000x' number with the number for outgoing. The last digits is left unchanged. This works for 10 numbers. So there is a second rule for '8001x', etc.
You can test rules with:
test voice translation-rule
I have a scenario where I have more than 20 extensions in no particular order. I presently map DIDs inbound to these 20 extensions using these dial-peers:
dial-peer voice 702 pots
translation-profile incoming DID1
incoming called-number 688.
direct-inward-dial
dial-peer voice 703 pots
translation-profile incoming DID2
incoming called-number 689.
direct-inward-dial
Now I am only able to apply one translation profile to the outbound POTs peer. How do I get all these translations to appear on a single outbout POTS?
dial-peer voice 101 pots
trunkgroup 1
translation-profile outgoing DID1
destination-pattern 91..........
direct-inward-dial
forward-digits 11
Please open new thread for new problems. In you case, details what you need to do with numbers.
1363
