Voice Translation Rules HELP required
Hi there,
I am doing voice translation for the following scenario but I believe it can be done better way. So please suggest me how can I do this in one rule rather than two separate.
Basically I wanted to do digit manipulation for the range of 01726293700 - 899 to internal five digits 53500 - 53699. The way I have done, it also works but I have this to be done better way. Any suggestions
voice translation-rule 1
rule 1 /^017262937\(..\)/ /535\1/
rule 2 /^017262938\(..\)/ /536\1/
CUBE#test voice translation-rule 1 01726293719
Matched with rule 8
Original number: 01726293719    Translated number: 53519
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
CUBE#test voice translation-rule 1 01726293819
Matched with rule 9
Original number: 01726293819    Translated number: 53619
You have done it pretty well. I dont think there would be any other better way...
Hall of Fame Super Silver
Re: Voice Translation Rules HELP required
I concur, this is as good as it gets.
Chris
Thank you everyone
193
