**Voice Translations Rules issues with DID´s**
Hi guys,
I´m facing a little trouble with new extensions in the building, we already have 16XX and 17XX with DID starting with 2020XXXX and the problem is that new arriving dependencies  have the same range of ext like 1601,02,1705,1716 and so on. So I suggested to add a 4 at the beggining of the ext to avoid overlap and that means to make translations rules for the new range DID´s starting with 2033"16XX" and 2033"17XX".
I created this:
voice translation-rule 4
rule 1 /^01812033/ /4\4/
rule 2 /^2033/ /4\4/
voice translation-profile DNIS
translate called 4
when i simulate the incoming call looks like this:
test voice translation-rule 4 20331601
Matched with rule 2
Original number: 20331601       Translated number: 41601
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
so i thought that its gonna work  that way and created a dial-peer to hit those new ext (e.g to 41601)
dial-peer voice 10 voip
translation-profile outgoing DNIS
destination-pattern 41...
modem passthrough nse codec g711ulaw
session target ipv4:10.153.50.15
dtmf-relay h245-alphanumeric
dtmf-interworking rtp-nte
codec g711alaw
But when I make the calls only get the fast busy tone so made a debug ccapi inout and instead of 4 it is adding a 3
Jul 17 00:06:42.406: //-1/98402A5AA477/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=8122221000
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=31601
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 17 00:06:42.406: //-1/98402A5AA477/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x138E3D94, Call Info(
  Calling Number=8122221000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=31601(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=PSTN, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=200)
Jul 17 00:06:42.406: //-1/98402A5AA477/CCAPI/ccCheckClipClir:
   In: Calling Number=8122221000(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=8122221000(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jul 17 00:06:42.406: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 17 00:06:42.406: :cc_get_feature_vsa malloc success
Jul 17 00:06:42.406:  cc_get_feature_vsa count is 1
Jul 17 00:06:42.406: :FEATURE_VSA attributes are: feature_name:0,feature_time:319514792,feature_id:25639
Jul 17 00:06:42.406: //25639/98402A5AA477/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8122221000(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=31601(TON=Unknown, NPI=Unknown))
Jul 17 00:06:42.406: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=31601
Jul 17 00:06:42.406: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Jul 17 00:06:42.406: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=31601, Expanded String=31601, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Jul 17 00:06:42.406: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
   Result=Success(0); Incoming Dial-peer=3 Is Matched
   Result=Success(0); Incoming Dial-peer=4 Is Matched
   Result=Success(0); Incoming Dial-peer=5 Is Matched
   Result=Success(0); Incoming Dial-peer=6 Is Matched
   Result=Success(0); Incoming Dial-peer=9 Is Matched
   Result=Success(0); Incoming Dial-peer=8 Is Matched
Jul 17 00:06:42.406: //25639/98402A5AA477/CCAPI/cc_process_call_setup_ind:
   Event=0x13D5C588
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Jul 17 00:06:42.406: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 31601
Jul 17 00:06:42.406: //25639/98402A5AA477/CCAPI/ccCallSetContext:
   Context=0x130D2A98
   >>>>CCAPI handed cid 25639 with tag 1 to app "_ManagedAppProcess_Default"
Jul 17 00:06:42.406: //25639/98402A5AA477/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jul 17 00:06:42.406: //-1/98402A5AA477/DPM/dpMatchCore:
   Result=-1
   Result=-1
   Dial String=31601, Expanded String=31601, Calling Number=31601T
   Result=-1
   Match Rule=DP_MATCH_ANSWER; Calling Number=31601
   Dial String=, Expanded String=, Calling Number=31601T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=31601
   Result=-1
   Result=-1
   Result=-1
   Result=-1
Jul 17 00:06:42.410: //-1/98402A5AA477/DPM/dpMatchCore:
   Result=-1
Jul 17 00:06:42.410: //25639/98402A5AA477/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Jul 17 00:06:42.410: //25639/98402A5AA477/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 17 00:06:44.642: //25639/98402A5AA477/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x138E3D94, Tag=0x0, Call Id=25639,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 17 00:06:44.642: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 00:06:44.642: :cc_free_feature_vsa freeing 130B68A0
Jul 17 00:06:44.642:  vsacount in free is 0
If I use the num-exp 31601 41601 it works fine but then I would have to input every single ext and more coming, about 160.
I am Leaving the gw config for those kind persons that would like to help me and in return I will fully rate you guys.
Thanks in advance.
Everyone's tags (3)
Bronze
Re: **Voice Translations Rules issues with DID´s**
I guess you are receiving last 5
digits in the first place from your provider, not 4 digits.
Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Hi Ashok
Yeah it is probable, do you have any suggestion in this scenario? I made another translation rule but still the same.
VIP Super Bronze
Can you try this..
rule 1 /^01812033\(....\)/ /4\1/
rule 2 /^2033\(....\)/ /4\1/
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi aokanlawon,
already tried that and the result is the same, fast busy tone and the debug show this:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=31601
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 17 22:33:38.026: //-1/C21D12519C66/CCAPI/cc_api_call_setup_ind_common:
Jul 17 22:33:38.026: //-1/C21D12519C66/CCAPI/ccCheckClipClir:
Jul 17 22:33:38.026: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 17 22:33:38.026: :cc_get_feature_vsa malloc success
Jul 17 22:33:38.026:  cc_get_feature_vsa count is 5
Jul 17 22:33:38.026: :FEATURE_VSA attributes are: feature_name:0,feature_time:319519720,feature_id:29651
Jul 17 22:33:38.026: //29651/C21D12519C66/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Jul 17 22:33:38.026: //29651/C21D12519C66/CCAPI/cc_process_call_setup_ind:
   Event=0x13D5C588
Jul 17 22:33:38.026: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Jul 17 22:33:38.026: //29651/C21D12519C66/CCAPI/ccCallSetContext:
   Context=0x1313809C
   >>>>CCAPI handed cid 29651 with tag 1 to app "_ManagedAppProcess_Default"
Jul 17 22:33:38.026: //29651/C21D12519C66/CCAPI/ccCallProceeding:
Jul 17 22:33:38.026: //29651/C21D12519C66/CCAPI/ccCallDisconnect:
Jul 17 22:33:38.026: //29651/C21D12519C66/CCAPI/cc_api_get_transfer_info:
Jul 17 22:33:40.250: //29651/C21D12519C66/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x138E3D94, Tag=0x0, Call Id=29651,
________________________________________________________________________________-
any clue bro?
VIP Super Bronze
Please attach the full debug voip ccapi inout here.Include the calling and called number
im calling from an internal ext (3761) we have 1 gw for outgoing calls and 2 gw´s for incoming, the related config is just for incoming calls but in a failover scenario we should use those gw´s for outgoing.
Calling number: 22221000
Called number: 20331601
                                                             This is all the output from the gw
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=31601
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 17 22:50:00.552: //-1/0BBEB76F9CB3/CCAPI/cc_api_call_setup_ind_common:
Jul 17 22:50:00.552: //-1/0BBEB76F9CB3/CCAPI/ccCheckClipClir:
Jul 17 22:50:00.552: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 17 22:50:00.552: :cc_get_feature_vsa malloc success
Jul 17 22:50:00.552:  cc_get_feature_vsa count is 5
Jul 17 22:50:00.552: :FEATURE_VSA attributes are: feature_name:0,feature_time:319516360,feature_id:29672
Jul 17 22:50:00.552: //29672/0BBEB76F9CB3/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Jul 17 22:50:00.556: //29672/0BBEB76F9CB3/CCAPI/cc_process_call_setup_ind:
   Event=0x13D5C588
Jul 17 22:50:00.556: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Jul 17 22:50:00.556: //29672/0BBEB76F9CB3/CCAPI/ccCallSetContext:
   Context=0x130CAE18
   >>>>CCAPI handed cid 29672 with tag 1 to app "_ManagedAppProcess_Default"
Jul 17 22:50:00.556: //29672/0BBEB76F9CB3/CCAPI/ccCallProceeding:
Jul 17 22:50:00.556: //29672/0BBEB76F9CB3/CCAPI/ccCallDisconnect:
Jul 17 22:50:00.556: //29672/0BBEB76F9CB3/CCAPI/cc_api_get_transfer_info:
Jul 17 22:50:02.788: //29672/0BBEB76F9CB3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x138E3D94, Tag=0x0, Call Id=29672,
Jul 17 22:50:02.788: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 22:50:02.788: :cc_free_feature_vsa freeing 130B6EC0
Jul 17 22:50:02.788:  vsacount in free is 4
Jul 17 22:50:10.712: //29670/00D657679CAD/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x138E3D94, Call Id=29670
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 17 22:50:10.712: //29670/00D657679CAD/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=29670
Jul 17 22:50:10.712: //29671/00D657679CAD/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 17 22:50:10.712: //29671/00D657679CAD/CCAPI/cc_api_get_transfer_info:
Jul 17 22:50:10.712: //29670/00D657679CAD/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jul 17 22:50:10.712: //29670/00D657679CAD/CCAPI/cc_api_get_transfer_info:
Jul 17 22:50:10.716: //29671/00D657679CAD/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x139CA940, Tag=0x0, Call Id=29671,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Jul 17 22:50:10.716: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 22:50:10.716: :cc_free_feature_vsa freeing 130B7400
Jul 17 22:50:10.716:  vsacount in free is 3
Jul 17 22:50:12.712: //29670/00D657679CAD/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x138E3D94, Tag=0x0, Call Id=29670,
Jul 17 22:50:12.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 17 22:50:12.712: :cc_free_feature_vsa freeing 130B6980
Jul 17 22:50:12.712:  vsacount in free is 2
VIP Super Bronze
I am confused..This is an outbound call...Th trace you have sent shows the call matches voip inboound dial-peer 1. The config you have attached has a pots dial-peer for dial-peer 1..The called num,ber doesnt match what you have configured for the translation rule..Am I missing something
This 2 gw´s have the same config, I created a Route List in CUCM in case of failover to give outbound calls. So that´s why it is configured with pots and dial-peer 1 is for local calls, but honestly i dont know why calls are landing on this one and the weird behaviour of gw. I can give you access from mi pc if you want to resolve the mistery haha
thanks.
Bronze
Pls try with the below rule which should resolve your issue.
rule 1 /^3\(....\)/ /4\1/
Ashok
Ashok,
I did it your way and when simulated with the test command  didnt match the rule:
20331601 Didn't match with any of rules
So made some changes:
rule 1 /3\(....\)$/ /4\1/ for last digits and rule 1 /^3\(....\)$/ /4\1/ for axact match but still the same result as the past output in debug.
If I make a different call to another ext (3761) it lands first on dial-peer 1 pots and then 331 for outgoing and this is working just fine :
   cisco-username=
   cisco-ani=8183902081
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=33761
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 18 03:39:29.053: //-1/7C2D9E179E27/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=8183902081,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33761(TON=Unknown, NPI=Unknown),
Jul 18 03:39:29.053: //-1/7C2D9E179E27/CCAPI/ccCheckClipClir:
   In: Calling Number=8183902081(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=8183902081(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jul 18 03:39:29.053: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 18 03:39:29.053: :cc_get_feature_vsa malloc success
Jul 18 03:39:29.053:  cc_get_feature_vsa count is 1
Jul 18 03:39:29.053: :FEATURE_VSA attributes are: feature_name:0,feature_time:319515016,feature_id:29769
Jul 18 03:39:29.053: //29769/7C2D9E179E27/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8183902081(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33761(TON=Unknown, NPI=Unknown))
Jul 18 03:39:29.053: //29769/7C2D9E179E27/CCAPI/cc_process_call_setup_ind:
   Event=0x13D61250
Jul 18 03:39:29.053: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 33761
Jul 18 03:39:29.053: //29769/7C2D9E179E27/CCAPI/ccCallSetContext:
   Context=0x1313955C
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 29769 with tag 1 to app "_ManagedAppProcess_Default"
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/ccCallProceeding:
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=331, Params=0x1313192C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/ccCheckClipClir:
   Destination Pattern=33..., Called Number=3761, Digit Strip=FALSE
   Called Number=3761(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=7C2D9E17-EE92-11E2-9E27-B3306AEDEDF9, Outgoing Dial-peer=331
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3761
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x139CA940, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=8183902081,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3761(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=331, Call Count On=FALSE,
   Source Trkgrp Route Label=PSTN, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Jul 18 03:39:29.057: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 18 03:39:29.057: :cc_get_feature_vsa malloc success
Jul 18 03:39:29.057:  cc_get_feature_vsa count is 2
Jul 18 03:39:29.057: :FEATURE_VSA attributes are: feature_name:0,feature_time:319519720,feature_id:29770
Jul 18 03:39:29.057: //29770/7C2D9E179E27/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jul 18 03:39:29.057: //29770/7C2D9E179E27/CCAPI/ccCallSetContext:
   Context=0x131318DC
Jul 18 03:39:29.057: //29769/7C2D9E179E27/CCAPI/ccSaveDialpeerTag:
Jul 18 03:39:29.065: //29770/7C2D9E179E27/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Jul 18 03:39:29.065: //29770/7C2D9E179E27/CCAPI/cc_api_call_proceeding:
   Interface=0x139CA940, Progress Indication=NULL(0)
Jul 18 03:39:29.469: //29770/7C2D9E179E27/CCAPI/cc_api_set_called_ccm_detected:
Jul 18 03:39:29.469: //29770/7C2D9E179E27/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Jul 18 03:39:29.469: //29770/7C2D9E179E27/CCAPI/cc_api_call_alert:
   Interface=0x139CA940, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jul 18 03:39:29.469: //29769/7C2D9E179E27/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jul 18 03:39:29.469: //29770/7C2D9E179E27/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x139CA940, Call Id=29770
Jul 18 03:39:29.469: //29770/7C2D9E179E27/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Jul 18 03:39:29.469: //29770/7C2D9E179E27/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Jul 18 03:39:29.469: //29769/7C2D9E179E27/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=29769
Jul 18 03:39:47.293: //29769/7C2D9E179E27/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x138E3D94, Call Id=29769
Jul 18 03:39:47.293: //29769/7C2D9E179E27/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=29769
Jul 18 03:39:47.297: //29770/7C2D9E179E27/CCAPI/ccCallDisconnect:
Jul 18 03:39:47.297: //29770/7C2D9E179E27/CCAPI/cc_api_get_transfer_info:
Jul 18 03:39:47.297: //29769/7C2D9E179E27/CCAPI/ccCallDisconnect:
Jul 18 03:39:47.297: //29769/7C2D9E179E27/CCAPI/cc_api_get_transfer_info:
Jul 18 03:39:47.297: //29770/7C2D9E179E27/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x139CA940, Tag=0x0, Call Id=29770,
Jul 18 03:39:47.297: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 18 03:39:47.297: :cc_free_feature_vsa freeing 130B7BE0
Jul 18 03:39:47.297:  vsacount in free is 1
Jul 18 03:39:49.293: //29769/7C2D9E179E27/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x138E3D94, Tag=0x0, Call Id=29769,
Jul 18 03:39:49.293: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 18 03:39:49.293: :cc_free_feature_vsa freeing 130B6980
Jul 18 03:39:49.293:  vsacount in free is 0
Hope it helps!
Bronze
The above translation rule is to match with numbers staring with 3 like 3xxxx, not for your full DID number. The reason is below.
cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=31601 --> This is what you are receiving from your service provider.
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Can you please share your complete configuration as well as 'debug voip ccapi inout" for both 31601 and 37601 numbers dialing from outside?
Ashok
thanks for your reply ashok,
I leaved the rule as you suggest and made 3 different calls to ext 41601, 3761 and 2461 (2033"1601","3761" and "2461" respectively) so you can see the different dial-peers that are hited.
below is the complete router config and the result of debug.
I appreciate your help!
Bronze
Thanks for sharing the details.
The problem is "31xxx" is not matching to any dial peer in the first place so not able to route. Can you please apply the following translation rule on inbound dial peer (1) rather than outbound dial peer for 41xxx?
voice translation-rule 2000
rule 1 /31.../ /41/
voice translation-profile Test-New
translate called 2000
dial-peer voice 1 pots
trunkgroup PSTN
translation-profile outgoing Test-New
preference 1
destination-pattern [1-9].......
incoming called-number .
direct-inward-dial
forward-digits 8
If it still fails, then please try with applying above in incoming direction rather than outgoing. THis should help to get change the called number to 41xxx and then after match with your dial-peer 10.
Ashok
I did both incoming and outgoing rule profile in dial-peer voice 1 pots and the result is the same just hits it as inbound but doesnt strip the 3 and then fast busy tone so I created the num-exp for all ext starting with 41... and they are working fine just needed to remove the translation rule in that dial peer cause otherway if i leaved right there calls werent landing .
The next thing i need to make sure is that all of them will have outbound calls using this 2 gw´s with this config instead of the one that is doing the job right now.
I do prefer to make translation but users of those new ext already arrived so needed to fulfill service for them.
If you have any suggestion i would be glad to give it a try.
thanks!
Bronze
Glad to hear this.
Can you pls provide more details about this second requirement?
Ashok.
482
