Voice UDP port range
trinawong
Dear All,
What's the recommend UDP port range need open for IPT?
thanks a lot!
5 Replies 5
gogasca
Level 10
Level 10
For Cisco Ip telephony when using IP Phones CCM or VG we use a predefined range UDP ports in the range 16384 to 32764.
That would be the recommended I think
Thanks for your reply, any idea how about Avaya IPT system? Same UDP ports recommended?
Thank you,
If more users join, does it mean that need to expand the UDP port range? Thank you
VoIP UDP ports (RTP) should be the same, it?s doesn?t matter what vendor or voip protocol you are implemented unless the vendor itself specify it.
What you mean when you mention ?if more users join?
The range is from 16384 to 32764.
Don?t forget to open the Signaling TCP port.
Best regards.
Thanks your information about UDP ports range of Voice IP Protocol.
