Voicegateway FXO to cucm extension
we have 2921 router connected with 4 pstn line. and router added to the cucm 8.5 using h.323
how can i map one  pstn number 3424758xx to extension 2500 ?
i have mapped as below but when dial from outside to 3424758xx just ring no indication on 2500.
Foreign Exchange Office 0/1/0 Slot is 0, Sub-unit is 1, Port is 0
 Type of VoicePort is FXO
 Operation State is DORMANT
 Administrative State is UP
 No Interface Down Failure
 Description is not set
 Noise Regeneration is enabled
 Non Linear Processing is enabled
voice-port 0/1/0
 signal groundStart
 connection plar opx 2500
dial-peer voice 1 voip
 description VoIP Trunk to Cucm
 destination-pattern [1-9]...
 session target ipv4:172.25.25.16
 incoming called-number .
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 3 pots
 direct-inward-dial
dial-peer voice 4 pots
 port 0/1/0
Hi Frank, 1.) Is the number
Hi Frank,
1.) Is the number 2500 assigned to a phone/hunt-pilot?
2.) Do a debug voip dialpeer inout
Hi Zekeria,2500 assigned to
Hi Zekeria,
2500 assigned to the phone.
no output for above debug command
67
