Voicemail disabled / Unity Express 7.1
I am facing an issue with the unity express cue module. It is not possible to dial-in to the voicemail using the dial-in number specified in the CLI configuration.
CUESILU001# sh license in-use
StoreIndex:  0  Feature: VMIVR-VM-MBX                      Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: 30 /30
        License Priority: Medium
StoreIndex:  1  Feature: VMIVR-IVR-SESS                    Version: 1.0
        License Count: 2 /2
StoreIndex:  2  Feature: VMIVR-PORT                        Version: 1.0
        License Count: 2 /2
But:
CUESILU001# sh license status application voicemail
voicemail disabled, ivr session quantity (2) is equal to or exceeds available ports (2)
I believe this is the reason that voicemail is not functioning.
When performing a license activate I receive this message.
CUESILU001# license activate voicemail mailboxes 30
Current license already active, count saved for use at next reload
Does any of you guys know how I can solve this? Thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Voicemail disabled / Unity Express 7.1
Hi Brian,
What does this show now?
You will also need to relaod the box. Sorry I didn't mention that in my first post
Cheers!
Rob
Hi Brian,
To get you started can you please try;
service-module# no license activate ivr sessions
Cheers!
Rob
  Hi Rob
Now that is done
        License Count: 2 /2
Hi Brian,
Cheers!
Rob
Hi Rob
Now it looks like this. So this did the trick,
voicemail enabled: 2 ports, 2 sessions, 30 mailboxes
ivr disabled, ivr session activation count has been set to zero
however new problems:
1: now I cannot get my IVR script working because these ports are used for VM => 2 more licenses for IVR sessions must be purchased.
2: It did not solve the issue with my dial-in numbers as I thought it would, but I found this in my config:
sip
  session transport tcp
  transport switch udp tcp sip
Removing the session transport tcp under sip made it possible to use my dial-in numbers. Case closed
Thanks for your help Rob.
537
