Community Member
Voicemail is not connecting on the PC and iPhone over internet
Hi All,
Voicemail is working on Jabber LAN PC but over the internet voicemail is not connecting on the PC and iPhone. Please finds the attached screen shoot showing the error?
Pls advise urgent
1 ACCEPTED SOLUTION
Opening ports and the white
Opening ports and the white list configuration are not the same, again, have you white listed the CUC server???
java
if this helps, please rate
www.cisco.com/go/pdi
Apparently you forgot to
Apparently you forgot to mention youre using MRA for this...
java
Community Member
we are using MRA. Yes we have
we are using MRA.
Yes we have open all the ports as per the MRA document.
java
Community Member
Thanks Solved by white list
Solved by white list configuration .
186
