Voicemail license for CME 2951
Dear All,
I have Cisco CME 2951 and want to have voicemail for users. So how to check whether I have licenses for voicemail or how I can order the same.
Let me know if config needed.
Thank You,
Abhisar.
Abhisar,
Do you have a CUE module?
The CME 2951 router can't do voicemail by itself, you need to have a CUE module for that to work.
In other words licenses will not be neded on CME, noly on CUE and depends on the CUE version you have.
~ Luis Ramirez,
Re: Voicemail license for CME 2951
Dear Luis,
Thank you for your reply.
Regarding module, I dont  have idea, but I have attached show tech from the CME router, request if  you can check and let me know the information about the module and  voicemail license as I am not much aware about VOIP.
Thank You,
Abhisar.
Abhisar,
You do have a CUE module on the router.
SM-SRE-710-K9 on Slot 1.
interface SM1/0
ip unnumbered GigabitEthernet0/0.2
service-module ip address 10.1.1.2 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 10.1.1.1
Can you access thw IP address 10.1.1.2 through webpage?
Or perhaps use the following command to console the CUE?
service-module SM1/0 session
~Luis Ramirez,
200
