Community Member
Voicemail limit of UC520
what is the limit of total voicemail a UC520 can have ? currently the Maximum Caller Message Size is set to 240 seconds, but some callers are complaining, want to know the limit before I can increase it.
thanks
hasrat
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Voicemail limit of UC520
Hi Hasrat,
The Voicemail System Capacity is based on the number of "licensed" users (8,16..48)
Use this command to confirm what your system is set up for before making your changes.
It will look something like this;
UC500-CUE# show voicemail limits
Default Mailbox Size (seconds):         775
Default Caller Message Size (seconds):  60
Maximum Recording Size (seconds):       900
Default Message Age (days):             30
System Capacity (minutes):              480
Default Prompt Language:                systemDefault
Operator Telephone:                     211
Maximum Broadcast Size (seconds):       300
Broadcast Message Age (days):           30
Broadcast Message MWI:                  disabled
Play Caller Id:                         enabled
Mandatory Message Expiry:               disabled
Mailbox Selection:                      last-redirect
Hope this helps!
Rob
Hi Hasrat,
Hope this helps!
Rob
Community Member
Hi Rob,
Thank you it really helped.
hasrat
Hi Hasrat,
Glad to be of some help my friend
Cheers!
Rob
350
