voicemail messages in email
Hi Experts,
1. Is it possible for Unity Connection to send the voicemail messages as email attachments (wav files or some other audio file format) to users?
Any special licensing needed for this?
2. Can we achive this only for a subset of users on the unity connection?
Any pointers on how to achive this will be very helpful.
Many thanks for your time and attention.
Pete
1 ACCEPTED SOLUTION
Hi Pete.
Hi Pete. Yes it's possible and no additional license needed. Follow this thread to know how to achieve this. https://supportforums.cisco.com/discussion/10925101/unity-connection-71-email-notification-voicemail HTH Regards Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Pete.
thanks a lot for the timely
thanks a lot for the timely reply, Carlo!
47
