Voicemail problem - unity
I have set up a voicemail box and I am able to check voicemail internally in the company.
I am also able to dial into unity from externally to check the voicemail message using mobile phone.
However, it seems that when trying to dial into unity using landlines... then after i entered my extension the voicemail box said "invalid entry".. I have tried to use different phone outside of the company and it still the same.
however, if I dial into the unity checking the voicemail by dialing outside line then followed by the full number, it works..
it just didnt work when using any other landlines phone outside of the office( but work with mobile)
any idea?
Rachel
1 REPLY
Re: Voicemail problem - unity
possible work around would be to set up alternate extensions on that particular voice mail box. (be mind full to add exactly the number as it would be presented to unity (if you do any caller ID manipulation).
This is how I always set it up.
also can you debug dtmf? unsure if the caLL comes in via a IOS Voice gateway, but it is easy to debug dtmf on those
Please remember to rate useful posts, by clicking on the stars below.
146
