Voicemail shortcuts
Is there anyway that if I am listening to a user greeting that I can Fast foward through it?
Hall of Fame Super Red
Re: Voicemail shortcuts
Hi Michael,
I'm not sure what you are running for VM but in many systems the default is # (pound key) to Skip Greeting. Let us know what you have @ your end.
Cheers!
Rob
UnifiedM 5.0.1. I # and nothing happens.
If I recall.. ## is go to end of message..
Let me know if this helps..
Hi Michael,
This behaviour is based on the "Caller Input" section of the User Template that is used to create the mailboxes.
To Specify Caller Input Settings on a Subscriber Template
Step 1 In the Cisco Unity Administrator, go to any Subscribers > Subscriber Template > Caller Input page.
Step 2 Select a key from the Caller Input Map or from the keypad.
Step 3 Select an action.
Step 4 Indicate whether to lock the key to that action.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/administration/guide/ex/5xcusag210e.html#wp1048136
So, you need to Lock the # key to "Skip Greeting"
Cheers!
Rob
737
