Community Member
Voiceview Express: Playback Failed. Authentication Error
I have a UC520 with CUE 8.6.3. I recently factory reset the uc520 and started over again. After everything is setup, users cannot playback messages on general delivery mailboxes, hunt group boxes, or shared line boxes. Anything I can find is making sure the authentication URL is http://10.1.10.2/CCMCIP/authenticate.asp which it is. Web access is allowed. I'm all out of ideas. Here is my telephony-service:
telephony-service
video
fxo hook-flash
max-ephones 56
max-dn 224
ip source-address 10.1.1.9 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp cisco cisco
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7925 CP7925G-1.4.1SR1
load 7937 apps37sccp.1-4-4-0
load 7945 SCCP45.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 7975 SCCP75.9-1-1SR1S
load 521G-524G cp524g-8-1-17
time-zone 8
keepalive 30 auxiliary 4
voicemail 8599
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$WAZc$tjk4WNhgeiE5w/ODH9eiI.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 08:00 07:59
night-service day Mon 20:00 07:59
night-service day Tue 20:00 07:59
night-service day Wed 20:00 07:59
night-service day Thu 20:00 07:59
night-service day Fri 20:00 07:59
night-service day Sat 08:00 07:59
night-service date Dec 25 00:00 23:59
night-service date Dec 24 00:00 23:59
fac standard
create cnf-files version-stamp 7960 Dec 10 2013 12:50:25
1 ACCEPTED SOLUTION
Hello Marc,
Were any changes in telephony-service you made to make it work. I mean for URL for service and authentication.
Can you please try changing the
telephony-service is referencing:
Voiceview needs to use:
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
do no create and create cnf and reboot the phones .
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Hello Marc,
Br,
Nadeem
Community Member
Thank you! That was it. CCA put that in instead for whatever reason.
Thanks again!
157
