VoIP Auto Dialer for testing numbers
Tom Freeland
We are porting several thousand numbers over to SIP connectivity via the carrier in a couple of weeks. I need to find an auto dialer of sorts that will allow me to input a range of phone numbers and then have the dialer dial each number and report back on the status - fast busy, ring, voicemail, or whatever. I would love to rely on the carrier and their reporting information, but many hundreds of these lines are too critical to not actually test with an actual call. Doe anyone know of a good application that can do what I am describing?
Thanks.
Tom
Chris Deren
Some carriers use Empirix Hammer, but it is not cheap, will do exactly what you are describing:
http://www.empirix.com/solutions/products-services/hammer-test.aspx
HTH,
Chris
