VoIP Between India and US
We have a number of users in India that connect directly to a Cisco VoIP system in the US with their VoIP phones.  They connect over a MPLS circuit and there is nothing between their phone and the Cisco VoIP system in the US.  I have heard recently that the OSP changed something and maybe this is no longer allowed and that you need to first connect to a local India system and then "gateway" to the US.   Has anyone else heard this?
Thanks.
Personally I was always told that India didn't allow TEHO.
Yosh
HTH Regards, Yosh
That's correct, that's the reason geolocation configuration is required for India.
You can google this topic and find a lot of into.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
142
