Voip call drops after 15 seconds
The senarios is:
A(22222) ---hvic3-4fxs--- c2921 - c7206---isdn---Tel station---B(11111)
C (33333)---vic-2fxs--- c2620 - c7206---isdn---Tel station---B(11111)
This problem begins after changing c2620 to c2921, in several of our communication centers, with the same config. The inbound call from B to A drops after 15 seconds everytime.When I'm calling from telephone B to C (the same communication center with c2620 router) - everything is allright. This situation repeats everytime I'm calling to diferent comm.centers with new c2925 routers. As I understand - c2925 somehow sents disconect request after 15 seconds of normal call.
 Could you share your opinion, why it happens?
or advice me some diagnostic commands to solve this problem.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Get the following from both
Get the following from both sides:
debug cch323 all
debug h245 asn1
debug h225 asn1
debug h225 q931
debug voice ccapi inout
I think 15 seconds is probably the default H.245 timeout.  It might be one side is never sending a TerminalCapabilitySet or might be the H.245 socket fails to open at all.  A packet capture between the 2 may also be helpful.
VIP Super Bronze
You should start by looking
You should start by looking at your isdn logs to see why the call is dropping..
debug isdn q931
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi, i have already do this,
Hi, i have already do this, and The reason of disconnection is:
 Cause i = 0x80BF - Service/option not available, unspecified
, but there is no such command in c2925.
debug cch323 h245 + debug
debug cch323 h245 + debug ccH323 error    on c2921:
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_FASTSTART while at state IWF_IDLE
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/h245_iwf_set_new_state: changing from IWF_OLC_IDLE state to IWF_OLC_DONE state
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/fastStartIdle: H245_EV_OLC_IN/OUT_DONE sent to olc
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/h245_olc_in_sm: Received H245_EV_OLC_IN_DONE while at state H245_OLC_IN_STATE_IDLE
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/h245_olc_in_set_new_state: Changing from H245_OLC_IN_STATE_IDLE state to H245_OLC_IN_STATE_ESTABLISHED state
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/h245_olc_out_sm: Received H245_EV_OLC_OUT_DONE while at state H245_OLC_OUT_STATE_IDLE
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/h245_olc_out_set_new_state: Changing from H245_OLC_OUT_STATE_IDLE state to H245_OLC_OUT_STATE_ESTABLISHED state
Jun  2 18:13:50.218: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_BCF while at state IWF_OLC_DONE
Jun  2 18:13:55.153: //443/F428E0BA8AFC/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_LISTEN_REQ_EVENT
Jun  2 18:13:55.153: //443/F428E0BA8AFC/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_LISTEN_REQ_EVENT while at H245_NONE state
Jun  2 18:13:55.153: //443/F428E0BA8AFC/H323/cch323_h245_set_new_state: Changing from H245_NONE state to H245_WAITING state
Jun  2 18:13:55.153: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_BCF while at state IWF_OLC_DONE
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_h245_channel_established_ind: Using fd=5 to send msgs
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_send_event_to_h245_connection_sm: Changing to new event H245_ESTABLISHED_EVENT
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_h245_connection_sm: H245_LISTEN: Received event H245_ESTABLISHED_EVENT while at H245_WAITING state
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_h245_set_new_state: Changing from H245_WAITING state to H245_CONNECTED state
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_H245_CONNECTED while at state IWF_IDLE
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/h245_iwf_set_new_state: changing from IWF_IDLE state to IWF_AWAIT_CAP_MSD_RESP state
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_run_h245_cap_out_sm: Received H245_EVENT_CAP_REQ while at state IDLE
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/h245_cap_out_set_new_state: changing from IDLE state to AWAITING_RESPONSE state
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_run_h245_ms_sm: Received event H245_EVENT_MSD while at state H245_MS_NONE
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/cch323_run_h245_ms_sm: Sent MSD Request
Jun  2 18:13:55.161: //443/F428E0BA8AFC/H323/h245_ms_set_new_state: Changing from H245_MS_NONE state to H245_MS_OUTGOING_WAIT state       ---------    connection moment
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/cch323_run_h245_cap_out_sm: Received H245_EVENT_CAP_TIMER_EXPIRY while at state AWAITING_RESPONSE---------- disconnection moment after 15 sec
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/h245_cap_out_set_new_state: changing from AWAITING_RESPONSE state to IDLE state
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_CAP_REJ while at state IWF_AWAIT_CAP_MSD_RESP
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/h245_iwf_set_new_state: changing from IWF_AWAIT_CAP_MSD_RESP state to IWF_IDLE state
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/cch323_run_h245_ms_sm: Received event H245_EVENT_MS_TIMER_EXPIRY while at state H245_MS_OUTGOING_WAIT
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/cch323_run_h245_ms_sm: Error A, no response from remote endpoint
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/h245_ms_set_new_state: Changing from H245_MS_OUTGOING_WAIT state to H245_MS_NONE state
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_MSD_REJ while at state IWF_IDLE
Jun  2 18:14:10.161: //443/F428E0BA8AFC/H323/errHdlr: ERROR: Received Unexpected IWF_EV_MSD_REJ in state IWF_IDLE
Jun  2 18:14:10.173: //443/F428E0BA8AFC/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_IDLE
Jun  2 18:14:10.173: //443/F428E0BA8AFC/H323/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_IDLE
debug cch323 all
debug h245 asn1
debug h225 asn1
debug h225 q931
In c7206 debug I found the
In c7206 debug I found the reason of disconnection:
Jun  3 13:19:14.124: changing from H245_MS_NONE state to H245_MS_OUTGOING_WAIT state
Jun  3 13:19:14.124: timer (0x63AC4B40)starts - delay (15000)cch323_run_h245_ms_sm: Sent MSD Request
changing from H245_WAITING state to H245_CONNECTED state
and after 15 sec:
Jun  3 13:19:29.124: Timer[CCH323_H245_CAP_TIMER] expired
Set new event H245_EVENT_CAP_TIMER_EXPIRY, for callID 71816
but I don't understand from what side TCS not sends, could you, please, look at the debug files.
It looks like term mon didn't
It looks like term mon didn't get all of the debugs as some lines such as the incoming TCS were cut off.  This is fairly normal for these intensive debugs so we'll need to use a logging buffer instead.  Use this config:
no logging console
no logging monitor
logging buffered 5000000
service sequence-numbers
then run "clear log" from privilege exec and use "term len 0" and "show log" in order to view the logging buffer we set up.  That should prevent the messages from getting cut off
I hope this logs are more
I hope this logs are more infirmative)
As c7206 receives calls from different places very often  - records from other call may appears in 7206 log.
These logs definitely have
These logs definitely have more information.
I can see that after the 7206 receives the connect, it then sends a terminalCapabilitySet:
1529065: Jun  5 11:18:41.126: H225.0 INCOMING PDU ::=
R
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body connect :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
                },                h323 :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          conferenceID '6C80510AEBB811E39CE0837E4C6979E6'H
          callIdentifier
            guid '6C80510AEBB811E39CE1837E4C6979E6'H
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'C0010018800006000400000002'H
1529147: Jun  5 11:18:41.150: H245 MSC OUTGOING PDU ::=
RR
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 3 }
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 17
          capability receiveAndTransmitDataApplicationCapability :
            application nonStandard :
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              data '52747044746D6652656C6179'H
            maxBitRate 0
          capabilityTableEntryNumber 23
          capability receiveUserInputCapability : hookflash : NULL
          capabilityTableEntryNumber 22
          capability receiveUserInputCapability : dtmf : NULL
          capabilityTableEntryNumber 19
          capability receiveUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 4
          capability receiveAudioCapability : g729AnnexA : 8
          capabilityTableEntryNumber 3
          capability receiveAudioCapability : g729 : 8
          capabilityTableEntryNumber 9
          capability receiveAudioCapability : g7231 :
            maxAl-sduAudioFrames 3
            silenceSuppression FALSE
          capability receiveAudioCapability : g711Alaw64k : 20
          capabilityTableEntryNumber 8
          capability receiveAudioCapability : g728 : 16
          capabilityTableEntryNumber 7
          capability receiveAudioCapability : nonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723332'H
      capabilityDescriptors
          capabilityDescriptorNumber 1
          simultaneousCapabilities
              23
              22,
              19,
              17
              4,
              3,
              9,
              2,
              8,
              7
However, we do not see that TCS received on the 2921 side.  All we see is the 2921 sending its terminalCapabilitySet then waiting 15 seconds before timing out waiting to receive one from the 7206 and then sending the release complete:
008752: Jun  5 11:18:41.148: H245 MSC OUTGOING PDU ::=
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
        mcCapability
      capabilityTable
          capabilityTableEntryNumber 32
            application t38fax :
              t38FaxProtocol udp : NULL
              t38FaxProfile
                fillBitRemoval FALSE
                transcodingJBIG FALSE
                transcodingMMR FALSE
                version 0
                t38FaxRateManagement transferredTCF : NULL
                t38FaxUdpOptions
                  t38FaxMaxBuffer 200
                  t38FaxMaxDatagram 320
                  t38FaxUdpEC t38UDPRedundancy : NULL
            maxBitRate 144
          capabilityTableEntryNumber 6
          capabilityTableEntryNumber 5
          capabilityTableEntryNumber 11
          capabilityTableEntryNumber 10
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
              32,
              4,
              9,
              10,
              5,
              6,
              11
008863: Jun  5 11:18:56.156: //115/6C80510A9CE0/H323/run_h225_sm: Received event H225_EV_H245_FAILED while at state H225_WAIT_FOR_H245
008875: Jun  5 11:18:56.156: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling FALSE
It looks like the H245 messaging sent from the 7206 to the 2921 is getting dropped somewhere.  What's the network topology between these devices?  You may want to try packet captures on both sides.
Hello Brian,    Thank you for
Hello Brian,
    Thank you for answer, c2921 is connected directly to c7206 via E1 channel and I can't imagine where the h245  masseges could be dropped.
c7206 is the center of star-topology with lots of c2620 and one c2921 on another sides which are all connected via similar E1 channels. Also we made testing calls from some of c2620s on c2921 and everything was normal.
I've never tested E1 channels by packet captures - is it possible?
557
