11-27-2008 09:12 AM - edited 03-15-2019 02:47 PM
I need to know if a 2960 Catalyst Switch needs a special card o configuration to support VoIP. I can't find it on the specifications.
Thanks a lot
12-03-2008 03:02 PM
You can use Cisco Catalyst 2960-48TT Switch but you will need to use power injectors or MidSpans to power the phones for more number of users, you can say under 300 user's.
12-03-2008 03:28 PM
You will be just fine using your 2960 for VoIP. You will need power injectors/power supplies for your phones if you don't have one of the 2960 with PoE models.
HTH,
Mark
