VOIP Config on AS5400 Question without prefix ????
afzaalq007
Hi.
I have config my AS5400 for my VOIP Carrier termination as below configuratios are pasted,,,
dial-peer voice 1003 voip
description AAA-Voip
huntstop
incoming called-number 1003.T
voice-class codec 3
dtmf-relay h245-alphanumeric
fax protocol t38 ls-redundancy 2 hs-redundancy 2 fallback none
ip qos dscp cs5 media
dial-peer voice 10030 pots
huntstop
destination-pattern 1003.T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 1/7:D
forward-digits all
its working well and its ok ..
I want to ask that i want to config it without prefix "1003" this is our Voip carrier demand. so suggest me how can i do it and how can i made some chk on it with out prefix
waiting for ur reply
thanks and Regards
13 Replies 13
paolo bevilacqua
Sure, change both "incoming called-number" and "deatination-pattern" to match the number they are calling. Make sure you have "no digit-strip" on the pots DP.
hi
Thanks for the Ans!!! i was on leave
kindly can u tell me how can we do it any Example or any help DOC.
Waiting for ur reply
Just a normal configuration of dial-peer. Please see:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Hope this helps, if so please rate post!
hi
Thanks for the Ans
i will ckh and if i feel any prob will disscuss with you.
Thanks once agian.
My Dear Friend ..
I am still facing problem becoz i havt to config E.164 format (CC+number).
Can u provide congiguration exampls
Thanks and regards
I'm not sure what your problem is. You receive a number via IP and need to call PSTN ?
If the number always come in e.164 format most likely you will need to strip the CC for call within your country.
Use translation rules if necessary:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
hi
Thanks for ur sugestuion and i realy thanfull to you thant you are answering me and try o solve my problem.
Yesterday i have dicsus the thing wih my Customer and he told me in detal. that he said plz use our signaling IP as identifier instead of prefix.
So wht do u suggest me ????
once agian thanks for ur suggestions
Thanks and Regards
Afzaal Qadir
I have used translation rule to translate thier signaling IP to 1003 becoz we need prifix and its is our Requirment to use prefix so i have used this ..
AS5400#test voice translation-rule 1 203.89.8.5
Matched with rule 1
Original number: 203.89.8.5 Translated number: 1003
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
you use translation rules with telephone number and no IP address! Have you read the document about it ?
I have to say, I do not understand your problem exactly, would you try to describe it again, making some practical example ?
this my prob !!!
"We are unable to send the prefix 1003 that we are currently sending from the existing platform. Please confirm you can accept calls with the E.164 format (country code + number) from the Engine platform. Please use the signaling IPs listed below as the indentifer instead of the prefix 1003"
Where as it is our requirment to use the prfix 1003 i have send this prefix to my TB. as on the TOP i have to pasted my running config.
I have sudy the DOC are can translate only number.
e.g My carreir sends Call to us with 1003-92-300-XXXXXX
And now he wants to send only 92 XXX-xxxxx. i have to chk it with prefix (1003).
I think it may help u to understand the issue.
thanks
What is a TB? Where are you sending the call ?
Anyway, the following add 1003 for all calls coming via Voip thatare going to 92-xxx-xxxxx
In the incoming dial-peer, configure a translation to add 1003:
dial-peer voice XX voice
incoming called-number 92........ (assume fixed lenght 8 digits)
translation-profile incoming addprefix
voice translation-profile addprefix
translate called 100
voie translation-rule 100
rule 1 // /1003/
hi
Our Scaniro is
Internet----> (GAteyay Router/Firwall) ------> h.323Gatways ---->Teleco brige(TB) .
This our POP
The translation-rule above should add 1003. IF that deson't work you can apply it to 'outgoing' to the pots dial-peer.
