Voip dial-peer hairpinning
Howdy,
Is it possible to send calls from a Cisco Phone to CCM then out to a cisco gateway (2800) then across to another cisco gateway (2800) and back into Call Manager?
I've tried everything but Call Manager wont accept the inbound call unless it comes in from outside the gateway on a pots dial-peer first.
Call Manager ver - 6.1.2
Any ideas?
1 ACCEPTED SOLUTION
Re: Voip dial-peer hairpinning
i guess u use voip dial-peer to voip dial-peer
in this case if u use h323 dial-peers
try to add the following command
voice service voip
allow connection h323 to h323
this way mostly will work
good luck
hope this helpful
voice service voip
good luck
hope this helpful
That worked thanks!
u welcome :)
361
