Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VoIP Dial-peer load balancing
What is the best approach to balance load between two VoIP dialpeers that point to two different session target?
Set the same preference option for both dialpeers?? A example:
dial-peer voice 11111 voip
destination-pattern 9999999
preference 1
progress_ind setup enable 3
session protocol sipv2
session target ipv4:74.125.45.103
dtmf-relay rtp-nte
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
dial-peer voice 22222 voip
preference 1
session target ipv4:69.147.76.15
dtmf-relay rtp-nte
Thanks in advance.
1 ACCEPTED SOLUTION
Re: VoIP Dial-peer load balancing
Yes, the default in this case would be to send calls to the 2 dial peers in a random order which essentially works out to be load balancing. Also, the "preference 1" command is not necessary since the default is preference 0. Without this command, both dial peers would still have the same preference.
Hope this helps.
Brandon
Hope this helps.
Brandon
Thanks for your answer.
I was wondering if there is something like Trunkgroup, but instead of working with channels work with IP Address?
Regards.
Not to my knowledge. Another way to accomplish this would be by using DNS, such as:
session target dns:device.domain.com
You could then use DNS to load balance.
I think multiple dial peers with IP addresses and the same preference would be a better solution because it does not depend on DNS.
Hope this helps.
Brandon
where i can find info on load balancing using dns?
thanks,
The exact implementation would depend on the DNS server that you are using. The following link gives a general description.
http://en.wikipedia.org/wiki/Round_robin_DNS
Essentially, load balancing using DNS uses a round-robin algorithm to distribute the load. This method is not perfect, but may do the job for you.
Hope this helps.
Brandon
Hi Brandon,
So it would load balance and not select the first dial peer configured?
With DNS load balancing, you would only have one dial peer. This dial peer would point to a FQDN such as gateways.domain.com. Your DNS server would then take care of the load balancing by distributing the calls among IP addresses that it has configured for gateways.domain.com.
Brandon
I would need to look into this more - but I believe IOS may cache the DNS reference it receives. I'm not 100% positive if it receives a reply with multiple IP addresses that it load balances. It should, just never seen or tested it myself. I would check this before depending on it.
-nick
Hi Brandon,
would you have a document that explains the configuration needed on the dns server and the gateyway? configuring the dns server seems challenging.
Another option would be to load balance using dial peers, is it done using hunt groups?
thanks for your feedback,
I've only seen POTS peers set up for hunt groups. I am curious how dial peers with IP addressing and not DNS will load balance. I thought the router would take the first configured dial peer in the configuration if two dial peers had the same match.
Hall of Fame Super Gold
Same preference DPs are used round-robin, no matter if pots or voip.
That pretty much summarizes the way it works.
Great, thanks.
You're welcome, thank you for the nice rating and good luck.
i have used these the below dial-peers and only the first one is matched:
dial-peer voice 3001 voip
destination-pattern 3002
session target ipv4:10.1.1.101
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 3002 voip
codec g711ulaw
no vad
They seem to be the same ?!?
Sorry for the confusion, i have used the below dial peers and the 3002 is always matched as the "show call hist voi br" is showing.
codec g711ulaw
no vad
session target ipv4:10.1.1.105
codec g711ulaw
no vad
13DF : 185 341511720ms.134 +60 +5130 pid:3002 Originate 3002
dur 00:00:05 tx:250/40000 rx:0/0 10 (normal call clearing (16))
IP 10.1.1.103:17058 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
13E6 : 186 341511760ms.135 +10 +5100 pid:85 Answer 571
dur 00:00:05 tx:0/0 rx:203/32480 10 (normal call clearing (16))
IP 10.1.1.103:18174 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
13EB : 187 341548470ms.136 +80 +3950 pid:556 Answer 571
dur 00:00:03 tx:0/0 rx:192/30720 10 (normal call clearing (16))
IP 192.168.0.11:26840 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
13EB : 188 341548490ms.137 +50 +3940 pid:3002 Originate 3002
dur 00:00:03 tx:192/30720 rx:0/0 10 (normal call clearing (16))
IP 10.1.1.103:18110 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
13F2 : 189 341548520ms.138 +0 +3930 pid:85 Answer 571
dur 00:00:03 tx:0/0 rx:145/23200 10 (normal call clearing (16))
IP 10.1.1.103:19514 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
13F7 : 190 341652040ms.139 +80 +7260 pid:556 Answer 571
dur 00:00:07 tx:0/0 rx:358/57280 10 (normal call clearing (16))
IP 192.168.0.11:26844 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
13F7 : 191 341652060ms.140 +40 +7260 pid:3002 Originate 3002
dur 00:00:07 tx:358/57280 rx:0/0 10 (normal call clearing (16))
IP 10.1.1.103:16832 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
13FE : 192 341652080ms.141 +20 +7250 pid:85 Answer 571
dur 00:00:07 tx:0/0 rx:311/49760 10 (normal call clearing (16))
IP 10.1.1.103:16810 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off
You must have something else causing that, In my experience load balancing works as described.
hi,
I discovered the problem, i needed to add "preference 1" on both dialpeers as mentioned in the SRND.
Where exactly is mentioned ? I wasn't aware of this requirement.
now you are :) page 61. cvp7srnd
sorry, I check page 61, PDF version of CUCM V7 SRND and can't find that, could you point me to a section and page in that book ?
Both dial-peers have the same destination.
1659
