VOIP Dial peer Selection
Dear Sir,
i want to throw calls from specific ANI to session target B. and for that I have implemented following dial-peers in which command answer address is used in second dial-peer  but its not working.
dial-peer voice 1001 voip
description Towards Advance VOIP
destination-pattern .T
voice-class codec 1002
session protocol sipv2
session target ipv4:A
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 9002 voip
description Office PRI Diversion
answer-address 512112152
voice-class codec 1001
session target ipv4:B
dtmf-relay rtp-nte
fax rate 9600
Can anybody please help me out. Thanks
Everyone's tags (3)
Hi please post the debug voice ccapi in & out for a test call.
regards,
Baskaran
Bronze
I agree with Baskaran that a debug would be most beneficial.  I can't help but speculate that you will need to match an outbound dial peer with a destination pattern as well.  But that is only a guess.
Here is a good read on dial peer selection
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic2
i put answer address also to 9002 dial-peer and nothing positive.its always reading 1001 voip dial-pper and not 9002.
Here is the O/P of debug voice ccapi inout command :
cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
6w5d: //-1/0A03AA8AA2C3/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x670C6BD4, Call Info(
   Calling Number=512112152,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1256(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3830, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
6w5d: //-1/0A03AA8AA2C3/CCAPI/ccCheckClipClir:
   In: Calling Number=512112152(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=512112152(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
6w5d: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
6w5d: :cc_get_feature_vsa malloc success
6w5d:  cc_get_feature_vsa count is 39
6w5d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723415032,feature_id:199583
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=512112152(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1256(TON=Subscriber, NPI=ISDN))
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_process_call_setup_ind:
   Event=0x66BA9AD0
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccCallSetContext:
   Context=0x67EEDB20
   >>>>CCAPI handed cid 199583 with tag 3830 to app "_ManagedAppProcess_Default"
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1001, Params=0x680DE210, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=1256, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=0A03AA8A-532E-11E1-A2C3-0003BAA7801F, Outgoing Dial-peer=1001
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x666A6238, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=512112152,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1256(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
6w5d:  cc_get_feature_vsa count is 40
6w5d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723422376,feature_id:199584
6w5d: //199584/0A03AA8AA2C3/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
6w5d: //199584/0A03AA8AA2C3/CCAPI/ccCallSetContext:
   Context=0x680DE1C0
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccSaveDialpeerTag:
6w5d: //199584/0A03AA8AA2C3/CCAPI/cc_api_call_proceeding:
   Interface=0x666A6238, Progress Indication=NULL(0)
6w5d: //199584/0A03AA8AA2C3/CCAPI/cc_api_call_connected:
   Interface=0x666A6238, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
6w5d: //199583/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x67A3ECE4, callID1=0x30B9F, callID2=0x30BA0, tag=0x0)
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccConferenceCreate:
   Conference Id=0x67A3ECE4, Call Id1=199583, Call Id2=199584, Tag=0x0
6w5d: //199583/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x16268, Source Interface=0x670C6BD4, Source Call Id=199583,
   Destination Call Id=199584, Disposition=0x0, Tag=0xFFFFFFFF
6w5d: //199584/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
6w5d: cc_api_get_xcode_stream : 4381
6w5d: //199584/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x16268, Source Interface=0x666A6238, Source Call Id=199584,
   Destination Call Id=199583, Disposition=0x0, Tag=0x0
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x16268, Destination Call Id=199584)
6w5d: //199584/0A03AA8AA2C3/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x16268, Destination Call Id=199583)
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=199584, Source Call Id=199583,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
6w5d: //199584/0A03AA8AA2C3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x670C6BD4, Destination Call Id=199583, Source Call Id=199584,
   Caps(Codec=0x4, Fax Rate=0x80, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=1)
6w5d: //199584/0A03AA8AA2C3/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_14400(0x80), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=7528)
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_api_caps_ack:
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x16268, Call Id1=199583, Call Id2=199584
6w5d: //199583/0A03AA8AA2C3/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
6w5d: //199583/0A03AA8AA2C3/CCAPI/cc_api_voice_mode_event:
   Call Id=199583
   Call Entry(Context=0x67EEDB20)
6w5d: //199583/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x30BA0
6w5d: //199583/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
6w5d: //199581/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x30BA0
6w5d: //199581/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit 4 to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x30BA0
   Consume mask is not set. Relaying Digit 8 to dstCallId 0x30B9E
6w5d: //199540/DC818B9D8525/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x66BF1B54, Call Id=199540
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
6w5d: //199539/DC818B9D8525/CCAPI/ccConferenceDestroy:
   Conference Id=0x16253, Tag=0x0
6w5d: //199539/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x16253, Source Interface=0x666A6238, Source Call Id=199539,
   Destination Call Id=199540, Disposition=0x0, Tag=0x0
6w5d: //199540/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x16253, Source Interface=0x66BF1B54, Source Call Id=199540,
   Destination Call Id=199539, Disposition=0x0, Tag=0x0
6w5d: //199539/DC818B9D8525/CCAPI/cc_generic_bridge_done:
6w5d: //199539/DC818B9D8525/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
6w5d: //199540/DC818B9D8525/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
6w5d: //199540/DC818B9D8525/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
6w5d: //199539/DC818B9D8525/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x666A6238, Tag=0x0, Call Id=199539,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
6w5d: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
6w5d: :cc_free_feature_vsa freeing 66B930A8
6w5d:  vsacount in free is 39
6w5d: //199540/DC818B9D8525/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66BF1B54, Tag=0x0, Call Id=199540,
6w5d: :cc_free_feature_vsa freeing 66B96198
6w5d:  vsacount in free is 38
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit 8 to dstCallId 0x30BA0
   Consume mask is not set. Relaying Digit 2 to dstCallId 0x30BA0
   Consume mask is not set. Relaying Digit 2 to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit 4 to dstCallId 0x30BA0
   Consume mask is not set. Relaying Digit 6 to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit 9 to dstCallId 0x30BA0
   Consume mask is not set. Relaying Digit # to dstCallId 0x30B9E
   Consume mask is not set. Relaying Digit # to dstCallId 0x30BA0
6w5d: //199581/081FEE7BA2BC/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=199581
6w5d: //199582/081FEE7BA2BC/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x666A6238, Call Id=199582
6w5d: //199581/081FEE7BA2BC/CCAPI/ccConferenceDestroy:
   Conference Id=0x16267, Tag=0x0
6w5d: //199581/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x16267, Source Interface=0x670C6BD4, Source Call Id=199581,
   Destination Call Id=199582, Disposition=0x0, Tag=0x0
6w5d: //199582/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x16267, Source Interface=0x666A6238, Source Call Id=199582,
   Destination Call Id=199581, Disposition=0x0, Tag=0x0
6w5d: //199581/081FEE7BA2BC/CCAPI/cc_generic_bridge_done:
6w5d: //199581/081FEE7BA2BC/CCAPI/ccCallDisconnect:
6w5d: //199581/081FEE7BA2BC/CCAPI/cc_api_get_transfer_info:
6w5d: //199582/081FEE7BA2BC/CCAPI/ccCallDisconnect:
6w5d: //199582/081FEE7BA2BC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x666A6238, Tag=0x0, Call Id=199582,
6w5d: :cc_free_feature_vsa freeing 66B95190
6w5d:  vsacount in free is 37
6w5d: //199581/081FEE7BA2BC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x670C6BD4, Tag=0x0, Call Id=199581,
6w5d: :cc_free_feature_vsa freeing 66B95418
6w5d:  vsacount in free is 36
6w5d: //-1/0F903660A2D0/CCAPI/cc_api_display_ie_subfields:
plz guide more so that my calls from ANI 512112152 always read 9002 voip dial-peer and not 1001.
Bronze
Re: VOIP Dial peer Selection
We need to see the configuration of your other dial-peers, in particular: Incoming Dial-peer=3830
Every call will have an inbound and an outbound call leg.  This call is matching Dial Peer 3830 on the inbound.
It does make sense though why Dial Peer 1001 is being matched on the outbound because you have a destination pattern command on it and you do not have one on dial peer 9002.
If I am guessing Dial Peer 3830 is a pots dial peer.
Dear Shane,
Actually my call is coming from PSTN and i recived that call from ANI 512112152 on pots dial peer 3820 and i want to move that call from dial-peer 9002 but it always reading dial-peer 1001 which is used for other numbers not for my ANI 512112152 that is :
DPs configs are :
translation-profile outgoing national
preference 2
session target ipv4:yyyy
dtmf-relay rtp-nte
fax rate 14400
dial-peer voice 3810 pots
tone ringback alert-no-PI
description ### FOR ORIGINATION POTS DIALPEER(used for other ANIs) ###
direct-inward-dial
port 7/3:D
dial-peer voice 3820 pots
description ### FOR ORIGINATION POTS DIALPEER ADDIng PREFIX ###
direct-inward-dial
port 7/3:D
dial-peer voice 9003 voip
description INCOMING DP - (add prefix 2299)
translation-profile incoming add-prefix
modem passthrough nse codec g711ulaw
session transport udp
dtmf-relay rtp-nte
fax rate 14400
fax protocol t38 ls-redundancy 2 hs-redundancy 2 fallback pass-through g711alaw
dial-peer voice 9004 voip
description OUT_SIP (strip prefix 2299)
translation-profile outgoing STRIP_PREFIX_2299
huntstop
preference 2
destination-pattern 2299T
session target ipv4:xxx
dtmf-relay rtp-nte
fax rate 9600
and translation profiles are :
voice translation-rule 11
rule 1 /^2299/ //
voice translation-rule 15
rule 1 /^\([0-9]\)/ /2299\1/
voice translation-profile STRIP_PREFIX_2299
translate called 11
voice translation-profile add-prefix
translate called 15
i used a trick here of digit padding and stripping but its not helpful. Can you please guide me some more. i pasted some debugs of this scenario. Always calls from ANI 512112152 reading 1001 dial-peer and not 9004.
Dial String=1256C, Expanded String=1256C, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
6w6d: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
6w6d: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=512112152
6w6d: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
   Dial String=, Expanded String=, Calling Number=512112152T
6w6d: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=3820 Is Matched
   Result=Success(0); Incoming Dial-peer=9003 Is Matched
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=1256C
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_FAX
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=1001,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3810,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3830,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=3820,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=9003,Peer Info Type=DIALPEER_INFO_SPEECH)
   OutboundSearch=FALSE, Peer Info Type=DIALPEER_INFO_FAX, Current Peer(Tag=9004,Peer Info Type=DIALPEER_INFO_SPEECH)
   Result=-1
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=512112152
   Result=-1
looking forward to hear from you.
regards,
bilal
Bronze
This is what I would do- Use dial peer 3820 to match the inbound and manipulate the called number prepending 2299 to the called number.  Then the destination pattern on 9004 will match 2299T and strip the 2299.
You were close.  You were just missing the digit manipulation on the inbound dial-peer.
translation-profile incoming add-prefix <<<<>>>>
answer-address 512112152 <<<<>>>>
direct-inward-dial
port 7/3:D
no translation-profile outgoing STRIP_PREFIX_2299  <<<<>>>>
huntstop
preference 2
destination-pattern 2299T  <<<<>>>>
dtmf-relay rtp-nte
fax rate 9600
voice translation-rule 15 <<<<>>>>
rule 1 /\(.*\)/ /2299\1/
translate called 15
no voice translation-rule 11
no voice translation-profile STRIP_PREFIX_2299
Dear Shane,
With  your help i have manage to perform the task successfully and call is  moving out from DP 9004 for my test ANI 512112152 and for rest of  numbers its reading DP 1001. The configs are :
preference 2
dtmf-relay rtp-nte
fax rate 14400
description ### FOR ORIGINATION POTS DIALPEER ###
direct-inward-dial
port 7/3:D
dial-peer voice 3830 pots
description ### FOR TERMINATION POTS DIALPEER #####
translation-profile outgoing national-outgoing
destination-pattern 92101T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 7/0:D
direct-inward-dial
port 7/3:D
huntstop
preference 2
session target ipv4:xxxx
dtmf-relay rtp-nte
fax rate 9600
translate called 11
translate called 15
rule 1 /^2299/ //
Thanks.
Now problem is i have multiple ANI to be shifted on DP 9004 through 3820 like we did for our test ANI 512112152.
ANIS are
512197115
514411810
for  this i used a trcik but its not helping. i create translation rule for  calling number and apply that on my incoming DP 3820 like :
voice translation-rule 16
rule 1 /^514411810/ /514411810/
rule 2 /^512112152/ /512112152/
rule 3 reject //
translate calling 16
translate called 15
and in POTS DP i removed answer address and used destination pattern in both pots that is 3810 and 3820.
direct-inward-dial
port 7/3:D
preference 1
direct-inward-dial
port 7/3:D
Also O/P of debug ccapi is :
>>>>CCAPI handed cid 245250 with tag 3810 to app "_ManagedAppProcess_Default"
7w0d: //245250/B29445809802/CCAPI/ccCallProceeding:
7w0d: //245250/B29445809802/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3810, Params=0x67EEA190, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
7w0d: //245250/B29445809802/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=1256C, Digit Strip=TRUE
   Called Number=1256C(TON=Subscriber, NPI=ISDN),
   Guid=B2944580-54EE-11E1-9802-0003BAA7801F, Outgoing Dial-peer=3810
7w0d: //245250/B29445809802/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
7w0d: //245250/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x670C6BD4, Interface Type=6, Destination=, Mode=0x0,
   Called Number=1256C(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3810, Call Count On=FALSE,
7w0d: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
7w0d: :cc_get_feature_vsa malloc success
7w0d:  cc_get_feature_vsa count is 46
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723410928,feature_id:245251
7w0d: //245251/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
7w0d: //245251/B29445809802/CCAPI/ccCallSetContext:
   Context=0x67EEA140
7w0d: //245250/B29445809802/CCAPI/ccSaveDialpeerTag:
7w0d: //245251/B29445809802/CCAPI/cc_api_call_proceeding:
   Interface=0x670C6BD4, Progress Indication=NULL(0)
7w0d: //245251/B29445809802/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x670C6BD4, Call Id=245251
   Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
7w0d: //245250/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
7w0d: //245251/B29445809802/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=245251
7w0d: //245251/B29445809802/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
7w0d: //245251/B29445809802/CCAPI/cc_api_get_transfer_info:
7w0d: //245251/B29445809802/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x670C6BD4, Tag=0x0, Call Id=245251,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
7w0d: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
7w0d: :cc_free_feature_vsa freeing 66B929E8
7w0d:  vsacount in free is 45
   Outgoing Dial-peer=3820, Params=0x6816F36C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
   Guid=B2944580-54EE-11E1-9802-0003BAA7801F, Outgoing Dial-peer=3820
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3820, Call Count On=FALSE,
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723410928,feature_id:245252
7w0d: //245252/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
7w0d: //245252/B29445809802/CCAPI/ccCallSetContext:
   Context=0x6816F31C
7w0d: //245252/B29445809802/CCAPI/cc_api_call_proceeding:
7w0d: //245252/B29445809802/CCAPI/cc_api_call_disconnected:
   Cause Value=21, Interface=0x670C6BD4, Call Id=245252
7w0d: //245252/B29445809802/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=245252
7w0d: //245252/B29445809802/CCAPI/ccCallDisconnect:
7w0d: //245252/B29445809802/CCAPI/cc_api_get_transfer_info:
7w0d: //245252/B29445809802/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x670C6BD4, Tag=0x0, Call Id=245252,
   Outgoing Dial-peer=1001, Params=0x67A5944C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
   Destination Pattern=.T, Called Number=1256C, Digit Strip=FALSE
   Guid=B2944580-54EE-11E1-9802-0003BAA7801F, Outgoing Dial-peer=1001
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=512112152
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1256C
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
7w0d: :FEATURE_VSA attributes are: feature_name:0,feature_time:1723410928,feature_id:245253
7w0d: //245253/B29445809802/CCAPI/ccIFCallSetupRequestPrivate:
7w0d: //245253/B29445809802/CCAPI/ccCallSetContext:
   Context=0x67A593FC
7w0d: //245253/B29445809802/CCAPI/cc_api_call_proceeding:
7w0d: //245253/B29445809802/CCAPI/cc_api_call_connected:
   Connection Handle=0
7w0d: //245250/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6803E160, callID1=0x3BE02, callID2=0x3BE05, tag=0x0)
7w0d: //245250/B29445809802/CCAPI/ccConferenceCreate:
   Conference Id=0x6803E160, Call Id1=245250, Call Id2=245253, Tag=0x0
7w0d: //245250/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE67, Source Interface=0x670C6BD4, Source Call Id=245250,
   Destination Call Id=245253, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //245253/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: cc_api_get_xcode_stream : 4381
7w0d: //245253/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE67, Source Interface=0x666A6238, Source Call Id=245253,
   Destination Call Id=245250, Disposition=0x0, Tag=0x0
7w0d: //245250/B29445809802/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1AE67, Destination Call Id=245253)
7w0d: //245253/B29445809802/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AE67, Destination Call Id=245250)
7w0d: //245250/B29445809802/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=245253, Source Call Id=245250,
7w0d: //245253/B29445809802/CCAPI/cc_api_caps_ind:
   Destination Interface=0x670C6BD4, Destination Call Id=245250, Source Call Id=245253,
7w0d: //245253/B29445809802/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=3409)
7w0d: //245250/B29445809802/CCAPI/cc_api_caps_ack:
7w0d: //245250/B29445809802/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AE67, Call Id1=245250, Call Id2=245253
7w0d: //245250/B29445809802/CCAPI/ccCallConnect:
7w0d: //245250/B29445809802/CCAPI/cc_api_voice_mode_event:
   Call Id=245250
   Call Entry(Context=0x67A5203C)
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_call_alert:
   Interface=0x66BF1B54, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
7w0d: //245246/BB9E397385B3/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
7w0d: //245246/BB9E397385B3/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=245246
7w0d: //245246/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6803DF20, callID1=0x3BDFE, callID2=0x3BDFF, tag=0x0)
7w0d: //245246/BB9E397385B3/CCAPI/ccConferenceCreate:
   Conference Id=0x6803DF20, Call Id1=245246, Call Id2=245247, Tag=0x0
7w0d: //245246/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: //245246/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE68, Source Interface=0x666A6238, Source Call Id=245246,
   Destination Call Id=245247, Disposition=0x0, Tag=0x0
7w0d: //245247/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE68, Source Interface=0x66BF1B54, Source Call Id=245247,
   Destination Call Id=245246, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //245246/BB9E397385B3/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1AE68, Destination Call Id=245247)
7w0d: //245247/BB9E397385B3/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AE68, Destination Call Id=245246)
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=245246, Source Call Id=245247,
7w0d: //245246/BB9E397385B3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x66BF1B54, Destination Call Id=245247, Source Call Id=245246,
7w0d: //245246/BB9E397385B3/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=9094)
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_caps_ack:
7w0d: //245246/BB9E397385B3/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AE68, Call Id1=245246, Call Id2=245247
7w0d: //245247/BB9E397385B3/CCAPI/cc_api_voice_mode_event:
   Call Id=245247
   Call Entry(Context=0x67A5DC54)
7w0d: //245250/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x3BE05
7w0d: //245250/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x3BE05
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x3BE05
7w0d: //245215/A5E723098565/CCAPI/cc_api_call_cut_progress:
   Interface=0x66BF1B54, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=4
   Call Entry(Responsed=TRUE)
7w0d: //245214/A5E723098565/CCAPI/ccCallProgIndProgress:
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_call_alert:
   Interface=0x66BF1B54, Progress Indication=INBAND(8), Signal Indication=NOT PRESENT(255)
7w0d: //245248/BBEE2D3985B8/CCAPI/ccCallAlert:
7w0d: //245248/BBEE2D3985B8/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=245248
7w0d: //245248/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x6803DCE0, callID1=0x3BE00, callID2=0x3BE01, tag=0x0)
7w0d: //245248/BBEE2D3985B8/CCAPI/ccConferenceCreate:
   Conference Id=0x6803DCE0, Call Id1=245248, Call Id2=245249, Tag=0x0
7w0d: //245248/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
7w0d: //245248/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE69, Source Interface=0x666A6238, Source Call Id=245248,
   Destination Call Id=245249, Disposition=0x0, Tag=0x0
7w0d: //245249/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1AE69, Source Interface=0x66BF1B54, Source Call Id=245249,
   Destination Call Id=245248, Disposition=0x0, Tag=0xFFFFFFFF
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1AE69, Destination Call Id=245249)
7w0d: //245249/BBEE2D3985B8/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1AE69, Destination Call Id=245248)
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_caps_ind:
   Destination Interface=0x666A6238, Destination Call Id=245248, Source Call Id=245249,
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_api_caps_ind:
   Destination Interface=0x66BF1B54, Destination Call Id=245249, Source Call Id=245248,
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=1, Seq Num Start=9578)
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_caps_ack:
7w0d: //245248/BBEE2D3985B8/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1AE69, Call Id1=245248, Call Id2=245249
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x3BE05
7w0d: //245249/BBEE2D3985B8/CCAPI/cc_api_voice_mode_event:
   Call Id=245249
   Call Entry(Context=0x67FABB50)
   Consume mask is not set. Relaying Digit 7 to dstCallId 0x3BE05
7w0d: //245254/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
7w0d: //-1/BEE39F2085C5/CCAPI/cc_api_display_ie_subfields
Please guide so that these other Ani will also follows 9004 DP to out to xxxx.
Bilal
Does dial-peer 3830 have "incoming called-number ." configured? Is it voip or pots?
2554
