voip dialpeer match problem with cme 8.6
I have a cisco 2821 router with cme version 8.6. I'm using ios c2800nm-ipvoicek9-mz.151-4.M3.bin
I have dialpeer match problem. debug voice dialpeer output is below.
014310: May  8 09:14:47.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=7743, Peer Info Type=DIALPEER_INFO_SPEECH
014311: May  8 09:14:47.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=7743
014312: May  8 09:14:47.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
014313: May  8 09:14:47.373: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=7743, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
014314: May  8 09:14:47.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=7700
CME_8.6#show dialplan number 7743 timeout
Macro Exp.: 7743
VoiceOverIpPeer7700
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `',
        tag = 7700, destination-pattern = `77..',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 7700, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        modem transport = system,
        URI classes:
            Incoming (Called) =
            Incoming (Calling) =
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        outgoing LPCOR:
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        mailbox selection policy: none
        type = voip, session-target = `ipv4:192.168.23.251',
        technology prefix:
        settle-call = disabled
        ip media DSCP = ef, ip media rsvp-pass DSCP = ef
        ip media rsvp-fail DSCP = ef, ip signaling DSCP = af31,
        ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
        ip video rsvp-fail DSCP = af41,
        ip defending Priority = 0, ip preemption priority = 0
        ip policy locator voice:
        ip policy locator video:
        UDP checksum = disabled,
        session-protocol = cisco, session-transport = system,
        req-qos = best-effort, acc-qos = best-effort,
        req-qos video = best-effort, acc-qos video = best-effort,
        req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
        req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
        RTP dynamic payload type values: NTE = 101
        Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
               CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
               A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, iSAC=124
               lmr_tone=0, nte_tone=0
               h263+=118, h264=119
               G726r16 using static payload
               G726r24 using static payload
        RTP comfort noise payload type = 19
        fax rate = voice,   payload size =  20 bytes
        fax protocol = system
        fax-relay ecm enable
        Fax Relay ans enabled
        Fax Relay SG3-to-G3 Enabled (by system configuration)
        fax NSF = 0xAD0051 (default)
        codec = g711ulaw,   payload size =  160 bytes,
        video codec = None
        voice class codec = `'
        voice class sip session refresh system
        voice class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
        voice class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
        voice class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
        voice class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
        text relay = disabled
        Media Setting = forking (disabled) flow-through (global)
        Expect factor = 10, Icpif = 20,
        Playout Mode is set to adaptive,
        Initial 60 ms, Max 1000 ms
        Playout-delay Minimum mode is set to default, value 40 ms
        Fax nominal 300 ms
        Max Redirects = 1, signaling-type = cas,
        VAD = disabled, Poor QOV Trap = disabled,
        Source Interface = NONE
        voice class sip url = system,
        voice class sip tel-config = system,
        voice class sip rel1xx = system,
        tvoice class sip outbound-proxy = system,
        voice class sip asserted-id = system,
        voice class sip privacy = system,
        voice class sip e911 = system,
        voice class sip history-info = system,
        voice class sip pass-thru headers = system,
        voice class sip pass-thru content unsupp = system,
        voice class sip pass-thru content sdp = system,
        voice class sip copy-list = system,
        voice class sip anat = system,
        voice class sip g729 annexb-all = system,
        voice class sip early-offer forced = system,
        voice class sip negotiate cisco = system,
        voice class sip reset timer expires 183 = system,
        voice class sip block 180 = system,
        voice class sip block 181 = system,
        voice class sip block 183 = system,
        voice class sip preloaded-route = system,
        voice class sip random-contact = system,
        voice class sip random-request-uri validate = system,
        voice class sip call-route p-called-party-id = system,
        voice class sip call-route history-info = system,
        voice class sip privacy-policy send-always = system,
        voice class sip privacy-policy passthru = system,
        voice class sip privacy-policy strip history-info = system,
        voice class sip privacy-policy strip diversion = system,
        voice class sip bandwidth audio  = system,
        voice class sip bandwidth video  = system,
        voice class sip error-code-override options-keepalive failure = system,
        voice class sip encap clear-channel  = system,
        voice class sip map resp-code 181 = system,
        voice class sip bind control = system,
        voice class sip bind media = system,
        voice class sip registration passthrough = System
        voice class sip authenticate redirecting-number = system,
        redirect ip2ip = disabled
        local peer = false
        probe disabled,
        Secure RTP: system (use the global setting)
        voice class perm tag = `'
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "",
        Last Disconnect Text is "",
        Last Setup Time = 0.
        Last Disconnect Time = 0.
Matched: 7743   Digits: 2
Target: ipv4:192.168.23.251
Runing config is below.
interface GigabitEthernet0/0.11
encapsulation dot1Q 11
ip address 192.168.25.190 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.25.190
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
modem passthrough nse codec g711ulaw redundancy
sip
  bind control source-interface GigabitEthernet0/0.11
  bind media source-interface GigabitEthernet0/0.11
voice class codec 5
codec preference 1 g729br8
codec preference 2 g729r8
voice register global
mode cme
source-address 192.168.25.190 port 5060
bandwidth video tias-modifier 100000 negotiate end-to-end
max-dn 18
max-pool 9
load 9971 sip9971.9-2-2SR1-9
timezone 48
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 005432543004659A
network-locale 1 U1
user-locale U1 TR
camera
video
voice register dn  4
number 7716
name Tel2
label 7716
voice register template  1
softkeys connected  Endcall Hold Trnsfer
voice register pool  2
busy-trigger-per-button 2
id mac xxxx.xxxx.xxxx
type 9971
number 1 dn 4
template 1
dtmf-relay cisco-rtp sip-notify
description Tel2
dial-peer voice 7700 voip
destination-pattern 77..
session target ipv4:192.168.23.251
codec g711ulaw
no vad
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
What did I see error? Could you advice me please.
Everyone's tags (5)
Hall of Fame Super Silver
What is the problem here?
Dial-peer 7700 is matched just fine as expected.
Chris
Hi, This problem still going. I don't understand where is the problem?
Log are below.
CME_8.6#
CME_8.6#
CME_8.6#
CME_8.6#
CME_8.6#
042435: Jul 19 07:16:02.650: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:6134846@192.168.23.251;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.17.108.130:5060;branch=z9hG4bK74f71bd1
From: "NOC2" <7792>;tag=ecc882b147c9008122d53908-04005126
To: <6134846>
Call-ID: ecc882b1-47c90009-7a6bd1db-4e493eae@172.17.108.130
Max-Forwards: 70
Date: Thu, 19 Jul 2012 07:16:01 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP9971/9.3.1
Contact: <7792>;video
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "NOC2" <7792>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.0,X-cisco-xsi-8.0.1
Allow-Events: kpml,dialog
Content-Length: 632
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 11235 0 IN IP4 172.17.108.130
s=SIP Call
t=0 0
m=audio 27004 RTP/AVP 0 8 18 102 9 116 124 101
c=IN IP4 172.17.108.130
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:9 G722/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:124 ISAC/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 26350 RTP/AVP 97
b=TIAS:1000000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42801E;packetization-mode=0;level-asymmetry-allowed=1
a=imageattr:* recv [x=640,y=480,q=0.50]
a=sendrecv
042436: Jul 19 07:16:02.650: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6134846, Called Number=6134846, Peer Info Type=DIALPEER_INFO_SPEECH
042437: Jul 19 07:16:02.650: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6134846
042438: Jul 19 07:16:02.650: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042439: Jul 19 07:16:02.654: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=6134846, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
042440: Jul 19 07:16:02.654: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=78871
     2: Dial-peer Tag=78873
042441: Jul 19 07:16:02.654: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7792, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
042442: Jul 19 07:16:02.654: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40007
042443: Jul 19 07:16:02.654: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
042444: Jul 19 07:16:02.654: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
042445: Jul 19 07:16:02.658: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
042446: Jul 19 07:16:02.658: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
042447: Jul 19 07:16:02.658: //-1/6E9A27879781/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7792, Called Number=6134846, Voice-Interface=0x0,
042448: Jul 19 07:16:02.658: //-1/6E9A27879781/DPM/dpAssociateIncomingPeerCore:
042449: Jul 19 07:16:02.658: //-1/6E9A27879781/DPM/dpMatchSafModulePlugin:
042450: Jul 19 07:16:02.658: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
042451: Jul 19 07:16:02.658: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4B746504
042452: Jul 19 07:16:02.658: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: (27876) Attribute mid, level 1 instance 1 not found.
SIP: (27876) Attribute mid, level 2 instance 1 not found.
042453: Jul 19 07:16:02.662: //27876/6E9A27879781/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
042454: Jul 19 07:16:02.662: //27876/6E9A27879781/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
042455: Jul 19 07:16:02.662: //27876/6E9A27879781/SIP/Error/sipSPI_ipip_update_call_entry:
042456: Jul 19 07:16:02.662: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 27876
042457: Jul 19 07:16:02.662: //27876/6E9A27879781/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
042458: Jul 19 07:16:02.666: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
042459: Jul 19 07:16:02.666: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4B743014
042460: Jul 19 07:16:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6134846, Peer Info Type=DIALPEER_INFO_SPEECH
042461: Jul 19 07:16:02.666: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042462: Jul 19 07:16:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042463: Jul 19 07:16:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=6134846, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
042464: Jul 19 07:16:02.670: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
042465: Jul 19 07:16:02.670: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042466: Jul 19 07:16:02.670: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042467: Jul 19 07:16:02.670: //-1/6E9A27879781/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
042468: Jul 19 07:16:02.670: //-1/6E9A27879781/DPM/dpMatchSafModulePlugin:
   dialstring=6134846, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
042469: Jul 19 07:16:02.670: //-1/6E9A27879781/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
042470: Jul 19 07:16:02.670: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
042471: Jul 19 07:16:02.674: //27876/6E9A27879781/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <6134846>
Date: Thu, 19 Jul 2012 07:16:02 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
042472: Jul 19 07:16:02.674: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:7792@172.17.108.130:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.23.251:5060;branch=z9hG4bK1BE6D6F
To: <7792>
Call-ID: 6E9DD110-D0A811E1-9786DABF-70B24351@192.168.23.251
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
User-Agent: Cisco-SIPGateway/IOS-12.x
Event: kpml; call-id=ecc882b1-47c90009-7a6bd1db-4e493eae@172.17.108.130; from-tag=ecc882b147c9008122d53908-04005126
Expires: 7200
Contact: <6134846>
Content-Type: application/kpml-request+xml
Content-Length: 358
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">[x#*]|bs
042473: Jul 19 07:16:02.694: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <7792>;tag=ecc882b147c9008262b8c579-669abbe1
CSeq: 101 SUBSCRIBE
Server: Cisco-CP9971/9.3.1
Contact: <7792>
Expires: 7200
Content-Length: 0
042474: Jul 19 07:16:02.698: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:6134846@192.168.23.251:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.108.130:5060;branch=z9hG4bK50099890
To: <6134846>;tag=4CE48CD0-1976
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Contact: <7792>
Content-Length: 0
042475: Jul 19 07:16:02.698: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
042476: Jul 19 07:16:02.698: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1000 NOTIFY
Content-Length: 0
CME_8.6#
CME_8.6#
CME_8.6#
CME_8.6#
CME_8.6#
CME_8.6#
042477: Jul 19 07:16:12.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.108.130:5060;branch=z9hG4bK6b9d0a9d
Date: Thu, 19 Jul 2012 07:16:11 GMT
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Contact: <7792>
Content-Length: 219
Content-Type: application/kpml-response+xml
Content-Disposition: session;handling=required
042478: Jul 19 07:16:12.690: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
042479: Jul 19 07:16:12.690: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 19 Jul 2012 07:16:12 GMT
CSeq: 1001 NOTIFY
Content-Length: 0
042480: Jul 19 07:16:12.694: //-1/6E9A27879781/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6134846T, Peer Info Type=DIALPEER_INFO_SPEECH
042481: Jul 19 07:16:12.694: //-1/6E9A27879781/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6134846T
042482: Jul 19 07:16:12.694: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042483: Jul 19 07:16:12.694: //-1/6E9A27879781/DPM/dpMatchSafModulePlugin:
   dialstring=6134846T, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
042484: Jul 19 07:16:12.694: //-1/6E9A27879781/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
042485: Jul 19 07:16:12.694: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
042486: Jul 19 07:16:12.698: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:7792@172.17.108.130:5060;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.23.251:5060;branch=z9hG4bK1BE7246
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Expires: 0
Contact: <6134846>
Content-Length: 0
042487: Jul 19 07:16:12.698: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
042488: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042489: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042490: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042491: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchSafModulePlugin:
042492: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=78873
     2: Dial-peer Tag=78871
042493: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042494: Jul 19 07:16:12.698: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042495: Jul 19 07:16:12.702: //-1/6E9A27879781/DPM/dpMatchPeersCore:
042496: Jul 19 07:16:12.702: //-1/6E9A27879781/DPM/dpMatchSafModulePlugin:
042497: Jul 19 07:16:12.702: //-1/6E9A27879781/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
042498: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042499: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042500: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042501: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
042502: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
042503: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6134846, Called Number=, Voice-Interface=0x0,
042504: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=78871
042505: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
042506: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
042507: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
042508: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
042509: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042510: Jul 19 07:16:12.702: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042511: Jul 19 07:16:12.706: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
042512: Jul 19 07:16:12.706: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
042513: Jul 19 07:16:12.706: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
042514: Jul 19 07:16:12.706: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
042515: Jul 19 07:16:12.706: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
042516: Jul 19 07:16:12.706: //27876/6E9A27879781/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:500, container:4B74697C
042517: Jul 19 07:16:12.710: //27876/6E9A27879781/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <6134846>;tag=4CE4B400-10EA
CSeq: 101 INVITE
Reason: Q.850;cause=63
Content-Length: 0
042518: Jul 19 07:16:12.718: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 SUBSCRIBE
Contact: <7792>
Expires: 0
Content-Length: 0
042519: Jul 19 07:16:12.718: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.108.130:5060;branch=z9hG4bK5127c25d
CSeq: 1002 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Contact: <7792>
Content-Length: 222
042520: Jul 19 07:16:12.718: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
042521: Jul 19 07:16:12.718: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
042522: Jul 19 07:16:12.722: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1002 NOTIFY
Content-Length: 0
042523: Jul 19 07:16:12.722: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:6134846@192.168.23.251;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
042524: Jul 19 07:16:12.726: //27876/6E9A27879781/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x496E1990
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 7792
Called Number            : 6134846
Source IP Address (Sig  ): 192.168.23.251
Destn SIP Req Addr:Port  : 172.17.108.130:5060
Destn SIP Resp Addr:Port : 172.17.108.130:49158
Destination Name         : 172.17.108.130
042525: Jul 19 07:16:12.726: //27876/6E9A27879781/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.23.251
Source IP Port    (Media): 18164
Destn  IP Address (Media): 172.17.108.130
Destn  IP Port    (Media): 27004
Orig Destn IP Address:Port (Media): [ - ]:0
042526: Jul 19 07:16:12.726: //27876/6E9A27879781/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 2
Negotiated Codec         :
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 97 (tx), 97 (rx)
Source IP Port    (Media): 16792
Destn  IP Port    (Media): 26350
042527: Jul 19 07:16:12.726: //27876/6E9A27879781/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 63
Disconnect Cause (SIP)   : 500
CME_8.6#
CME_8.6#
Your issue is this:
Sent:
CSeq: 101 INVITE
Content-Length: 0
Your SIP trunking does not appears to be setup properly.  Can you post your config?
Chris
Hi, It's below. But this configrations runing with 79xx phones now. Remember It's not runing 9971 phones only.
voice service voip
clid network-provided
supplementary-service h450.12
no supplementary-service sip moved-temporarily
redirect ip2ip
signaling forward rawmsg
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
  cause-code legacy
h323
sip
  bind control source-interface GigabitEthernet0/0.102
  bind media source-interface GigabitEthernet0/0.102
  registrar server expires max 1200 min 300
  early-offer forced
  no call service stop
voice class codec 5
dial-peer voice 78871 voip
translation-profile outgoing voipswitch
preference 9
service session
max-conn 3
destination-pattern 0[2-9].T
session protocol sipv2
session target ipv4:172.17.127.5
voice-class codec 5
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 78873 voip
preference 9
service session
max-conn 3
destination-pattern 05.T
voice-class codec 5
dtmf-relay rtp-nte
no vad
1700
