VoIP Gateway fail code in calls from SIP to PSTN
I have configured a Cisco 2901 router with VWIC3 card as VoIP gateway. But I'm having the following problem:
When I throw calls from de IP network (with Asterisk PBX) to the PSTN network, and the call is rejected by the end user, the call end never arrives to my Asterisk PBX. I can see in logs that the busy code arrives from PSTN to the 2901, but no SIP message is sent to the Asterisk PBX, so it can not know wich was the fail cause of the call.
Have I to set any additional option in "dial-peer" or in "voice service voip"?
The Asterisk PBX is connected to GigabitEthernet0/0 and the PSTN connection is an E1 primary trunk
My config file is:
isdn switch-type primary-net5
isdn voice-call-failure 500
voice service voip
signaling forward none
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
dial-peer voice 1 pots
description inbound calls from PSTN (inbound leg)
incoming called-number 936019999
direct-inward-dial
dial-peer voice 2 voip
description outbound calls from Asterisk (inbound leg)
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3 voip
description inbound calls to Asterisk (outbound leg)
destination-pattern 936019999
session target ipv4:89.1.23.205
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4 pots
description outbound calls from Asterisk (outbound leg)
destination-pattern .
port 0/0/0:15
Hi David,
under 'voice service voip', could you please try configuring 'signaling forward rawmsg' and remove 'signaling forward none'?
//Suresh Please rate all the useful posts.
Hi sureshsub2
I have tryied it (and also "unconditional"), but the SIP message with the fail reason is never generated. The "signaling forward rawmsg/unconditional" adds information in the SIP messages payload (183, session progress), but doesn't generate the SIP message, with the fail cause for Asterisk, when the end user rejects the call.
the cause code mapping between the pstn and sip is set by default. not sure why it is not generating the cause code in SIP leg. could you please provide the complete 'debug ccsip message & debug voip ccapi inout & debug isdn q931' for a test call
As you can see after the
Cause i = 0x829100000000 - User busy
arrives. The Cisco router doesn't send any SIP message. Only when the timeout for processing the call expires the Asterisk is who sends a CANCEL SIP message
Dec 30 18:29:54.266: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:192.10.28.3 SIP/2.0
Via: SIP/2.0/UDP 192.10.23.205:5060;branch=z9hG4bK2c35599d
Max-Forwards: 70
To: <192.10.28.3>
Contact:
Call-ID: 48ed11e60c33e0c65eaaa6bf4c0080ab@192.10.23.205:5060
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX 11.2.1
Date: Mon, 30 Dec 2013 18:39:38 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Content-Length: 0
Dec 30 18:29:54.266: //936/363EE66984D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <192.10.28.3>;tag=814B82A8-14C3
Date: Mon, 30 Dec 2013 18:29:54 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 437
v=0
o=CiscoSystemsSIP-GW-UserAgent 421 3247 IN IP4 192.10.28.3
s=SIP Call
c=IN IP4 192.10.28.3
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Dec 30 18:29:54.358: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.10.23.205:5060;branch=z9hG4bK5582f825
Max-Forwards: 70
To: <192.10.28.3>
Contact:
Call-ID: 45aef0dc39dbbae8048cee446b4f80db@192.10.23.205:5060
CSeq: 102 OPTIONS
Date: Mon, 30 Dec 2013 18:39:39 GMT
Content-Length: 0
Dec 30 18:29:54.362: //937/364CEFCA84D1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <192.10.28.3>;tag=814B8304-1A91
CSeq: 102 OPTIONS
Content-Length: 437
v=0
o=CiscoSystemsSIP-GW-UserAgent 334 4649 IN IP4 192.10.28.3
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Dec 30 18:30:02.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:626666666@192.10.28.3 SIP/2.0
Via: SIP/2.0/UDP 192.10.23.205:5060;branch=z9hG4bK039d95dd
Max-Forwards: 70
To: <626666666>
Contact:
Call-ID: 312213da7a749a831659a66c35662942@192.10.23.205:5060
CSeq: 102 INVITE
Date: Mon, 30 Dec 2013 18:39:46 GMT
Content-Length: 303
v=0
o=root 55449278 55449278 IN IP4 192.10.23.205
s=Asterisk PBX 11.2.1
c=IN IP4 192.10.23.205
t=0 0
m=audio 10678 RTP/AVP 3 0 8 101
a=rtpmap:3 GSM/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Dec 30 18:30:02.298: //938/3B07E01A84D2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <626666666>
Date: Mon, 30 Dec 2013 18:30:02 GMT
CSeq: 102 INVITE
Content-Length: 0
Dec 30 18:30:02.302: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num anonymous
Dec 30 18:30:02.302: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00A7 callID = 0x8028 switch = primary-net5 interface = User
Dec 30 18:30:02.302: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A7
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA9838A
        Exclusive, Channel 10
    Calling Party Number i = 0x01A0, 'anonymous'
        Plan:ISDN, Type:Unknown
    Called Party Number i = 0x81, '626666666'
Dec 30 18:30:02.394: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80A7
Dec 30 18:30:02.406: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80A7
    Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec 30 18:30:02.406: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sending: Binary Message Body
Dec 30 18:30:02.406: Content-Type: application/x-q931
08 02 00 A7 02 1E 02 82 88 0D 0A
Dec 30 18:30:02.410: //938/3B07E01A84D2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <626666666>;tag=814BA274-5A8
CSeq: 102 INVITE
Remote-Party-ID: <626666666>;party=called;screen=no;privacy=off
Contact: <626666666>
Supported: sdp-anat
Content-Type: multipart/mixed;boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 493
--uniqueBoundary
Content-Disposition: session;handling=required
v=0
o=CiscoSystemsSIP-GW-UserAgent 5199 9794 IN IP4 192.10.28.3
s=SIP Call
t=0 0
m=audio 18614 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
Content-Disposition: signal;handling=optional
Content-Length: 11
--uniqueBoundary--
Dec 30 18:30:04.814: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/0 (not half duplex), with SEP0004f2b01793 Port 1 (half duplex).
Dec 30 18:30:07.642: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80A7
Dec 30 18:30:07.642: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Dec 30 18:30:07.642: Content-Type: application/x-q931
08 02 00 A7 01 1E 02 82 88 0D 0A
Dec 30 18:30:07.646: //938/3B07E01A84D2/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 INVITE
Supported: sdp-anat
Mime-Version: 1.0
Content-Length: 493
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
--uniqueBoundary
Content-Length: 11
--uniqueBoundary--
Dec 30 18:30:12.834: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80A7
Dec 30 18:30:12.834: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8028
Dec 30 18:30:22.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:626666666@192.10.28.3 SIP/2.0
Max-Forwards: 70
To: <626666666>
CSeq: 102 CANCEL
Content-Length: 0
Dec 30 18:30:22.298: //938/3B07E01A84D2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <626666666>
Date: Mon, 30 Dec 2013 18:30:22 GMT
CSeq: 102 CANCEL
Content-Length: 0
Dec 30 18:30:22.306: //938/3B07E01A84D2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 102 INVITE
Reason: Q.850;cause=16
Content-Length: 0
Dec 30 18:30:22.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:626666666@192.10.28.3:5060 SIP/2.0
Max-Forwards: 70
Contact:
CSeq: 102 ACK
Content-Length: 0
Dec 30 18:30:22.318: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00A7
Dec 30 18:30:22.594: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80A7
Perhaps, It might be issue with the IOS. What is the IOS version??
"show sip-ua map pstn-sip" should display the correct mapping. Could you please check that once??
Could you please try "cause-code legacy" under voice service voip n see if that helps??
The problem seems to be that the CISCO postpone the forward of the call ends, as you can see in debug messages:
To solve it I have added
voice call disc-pi-off
in global configuration
With this option enabled the Cisco router sends the SIP message
SIP/2.0 486 Busy here.
when the disconnects arrives from the ISDN interface
Thanks for the update David. Good to know the issue is fixed.
550
