VOIP gateway
hi friend ..
what is the right VOIP GSM/CDMA   gateway    ???????
regards ...
1 REPLY
Re: VOIP gateway
Use AS5400 Gateway which is a TDM -IP, IP-IP Gateway, supports GSM Integration. I have tested the same.
Pl rate if the information is useful..Thanks.
138
