voip incoming call fail in E&M
Hi all,
I have voice gateway 2911 with VIC2-EM connected to analog PABX. I can make outgoing call from my phone via PABX and voice gateway to other region. However, my colleaque in other region call to me via voip. When finishing all digits, they get congestion tone. Could you help me to check what the problem is ?
dial-peer voice 10 pots
destination-pattern 552T
port 0/0/0
dial-peer voice 11 pots
port 0/0/1
dial-peer voice 12 pots
port 0/1/0
dial-peer voice 13 pots
port 0/1/1
dial-peer voice 777 voip
destination-pattern 777
session target ipv4:192.168.20.254
ip qos dscp cs5 media
ip qos dscp cs5 signaling
dial-peer voice 520 voip
destination-pattern 520T
session target ipv4:192.168.186.174
dtmf-relay h245-alphanumeric
codec g729r8 bytes 40
fax rate 9600
no vad
dial-peer voice 7 voip
destination-pattern 7T
session target ipv4:192.168.186.226
fax rate 9600
no vad
--More--                           !
dial-peer voice 551 voip
destination-pattern 551T
session target ipv4:192.168.186.166
fax-relay ecm disable
fax rate 9600
no vad dial-peer voice 10 pots
port 0/0/0
Thanks a lot
Leung
Hi all,
The following is the E&M config
voice-port 0/0/0
operation 4-wire
type 5
signal immediate
cptone CN
timeouts interdigit 2
voice-port 0/0/1
operation 4-wire
type 5
signal immediate
cptone CN
voice-port 0/1/0
operation 4-wire
type 5
signal immediate
cptone CN
voice-port 0/1/1
operation 4-wire
type 5
signal immediate
cptone CN
Leung
Green
Leung
What number is being called ?
What digits does your PBX want ?
Your current set up will be matching called numbers starting with
552.
The 552 wil be dropped and only the digits after the 552 wil be
sent to your PBX over the E&M
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Yes,  my colleaque dial 5528827 to me. The PABX accept 8827.  From the call history, it shows "call rejected".
Leung
325
