Community Member
voip monitoring tool
hi folks,
is there any tools available to monitor traffic b/w call manager and gateways/switch.
Community Member
Just wanted to add. I want to monitor the bandwidth from cucm to voice gateway.
Community Member
any thoughts anywone.
You would need to have a third party application to get a good utilization result.
Yosh
HTH Regards, Yosh
Community Member
thanks for the reply.
does rtmt tool provide me a bandwidth utilization report from cucm to gateway. can you suggest a few 3rd party tool.
thanks
hi 148west,
Why can't you  just use RTMT ?
Karthik
Community Member
karthik,
so i can use rtmt tool to find out how much bandwidth is utilized b.w cucm and gateway? if yes where in rtmt tool i can find this.
hi,
Yes  you can monitor using  Locations counter in RTMT. You can read more about it here...
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_0_2/rtmt/rtpmcm.pdf
check page B-22 of the above doc.
Also you can set alerts and threshold levels to alert you.
Hope this helps!
Karthik
631
