VOIP over ADSL
Hi, I am baffeled I am trying to run VOIP traffic from an elastix server over a Cisco 870 router. Call quality is fine untill more then a few people start surfing the internet. I have tried to enable some QOS on the router but with it  I can make one call and the rest just drops. I spend nearly a day surfing Cisco website and managed to come up with this config:
ip access-list extended DATA_TRAFFIC
permit tcp any any eq www
permit tcp any any eq 443
ip access-list extended VOIP_TRAFFIC
permit udp any any eq
permit tcp any any eq 5060
permit tcp any any eq 5061
permit tcp any any eq 10000
permit udp any any range 16348 32768
permit ip 10.6.49.66 255.255.255.255 any
class-map  VOIP_TRAFFIC
match access-name VOIP_TRAFFIC
class-map  DATA_TRAFFIC
match DATA_TRAFFIC
policy-map VOICE_QOS
class VOIP_TRAFFIC
priority percent 30
policy-map DATA_TRAFFIC
class DATA_TRAFFIC
bandwith percent 50
policy-map class-default
fairqeue
I have tried applying it to the Dialer and ATM interface. The show policy map command shows hits on every class, but call quality still drops and line availaibility drops to one line availaible. Does any know what I am doing wrong or of a better config?
Everyone's tags (3)
Blue
VOIP over ADSL
Have you tried config example present in QOS SRND, This is one of the best document for QOS for VOIP
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Ronak Patel
Please rate helpful posts by clicking starts below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
VOIP over ADSL
match protocol rtp              ----- this will match all real time voice traffic
and what is total bandwidth ?
and you will need one child policy and one parent
like this
class-map match-all voice
match protocol rtp
policy-map pm1                   ----- this is child policy
class voice
  priority 500                        ------ priority for all voice calls in kbps
  set precedence 5
class class-default
policy-map Shape                ----- this is parent policy, and should be applyed to interface
class class-default
  shape average 2000000          -----put here total bandwidth of your adsl line in bits per sec
  service-policy pm1
447
