05-05-2010 09:07 AM - edited 03-15-2019 10:37 PM
Greetings,
This is my first post. I hope I am at the correct forum.
My firm will be moving to a larger facility in the next few months. As budget is not an issue I want to install fiber throughtout our lan network.
My question is:
Is there a way to use the unused Ethernet port on the PCs the plug in the Cisco 7975 Voip phone and route back to Cisco router/switch.
05-05-2010 09:11 AM
Say again in other words? What is that you want to do, and what a PC port has to do with fiber?
Most important, are you a network engineer or an end user asking ?
05-05-2010 09:58 AM
Anything is possible; however, I would not recommend this:
I'm always glad to hear when customers say "budget is not an issue"; however, don't waste money. I can think of a dozen other things to invest in instead of fiber to the desk.
05-05-2010 10:02 AM
Well said and ditto!
Hailey
05-05-2010 10:18 AM
Thank you for your prompt and excellant reply. I'll do it
your way. But, we will connect servers,Sans etc. with fiber.
I really appreciate your help.
ken wood
Camarillo CA
