Voip Over GRE (one site behind an ASA Firewall)
Greetings to all.
i had a problem to establish a voip session between 2 sites as despicted on picture.image001.jpg
on site left, i had an 2851 ISR Router with running call manager express, in the other side of the tunnel gre i had an 2801 isr with fxo and fxs ports.
when i try to make a call with a phone or csim between sites i had connection attemps but no voip call is established.
i'll face several problems like Disconnect Cause=49, and others and i'll fixed with RSVP and other documents i'll found on cisco support site.
currently i don't know where to shoot to fix the problem.
note that some stuff are incomplette, because i'll need to go thru pstn on right side via PRI E1 interface, currently i'm using an FXO for testing prurposes
i'll attach the configurations of right, left, and right switch
after running debugs i capture them and attach'd as left-debug and right-debug.
i'll put those on both left and right routers.
debug cch323 session
debug cch323 function
debug cch323 error
debug ras
debug voice dialpeer inout
debug voice dialpeer function
debug voice dialpeer error
debug h225 asn1
debug h245 asn1
debug voip ccapi inout
i know the call voip fails, because after a 20 to 30 seconds, the call goes thru fxo port 0/1/0 on right side.
thanks for your time.
had a great day . best regards, and rate if you'll find this post useful
  • IP Telephony
Everyone's tags (4)
any questions about the problem ???
i'm glad to answer!
No one could help??
really no one knows ???
i'll fixed by my self!!
293
