Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VOIP Phone goes to VM after one ring??
I have a satellite office that has reported a sporadic issue. When they receive a call it rings one time and goes to VM as they will receive the message a couple minutes later. It happens sporadically 3-4 four times a day out of 50-100 calls received.
My first thought was how many people on the phones at a time and they say it could be 1 person in the office or 5 and the issue will occur.
Has anyone ever heard of this issue.
Is it a callmanager issue or a router issue? The connection to this office is a P2P T1 and we are using a 2800 Cisco Router with a Switch Module.
1 REPLY
Re: VOIP Phone goes to VM after one ring??
Sounds like you are running full-blown Communications Manager, and not CME?  No one is hitting iDivert, are they? :-P
Have you looked at a route plan report for that number to make sure there isn't any overlap of it matching a DN in another partition which has a different CFNA setting?
Detailed CM traces for a working call and a non-working call would shed light on what's happening under the hood.
134
