VoIP Phone Setup
Hello everyone,
I am interested in switching from analog telephone to VoIP, and I have recently purchased a Cisco 7942G VoIP phone.  I have a Cisco WAG310G modem with VoIP capability but it does not match because the VoIP socket on the modem is RJ-11 where the phone is RJ-45, so there is no way I could power up the phone without a power plug.
I am very new to this technology and would somebody please advice me how to set it up and get it working?
Kind Regads,
Ricky
Re: VoIP Phone Setup
Hello, as strange as this may sound, that DSL modem/router/gateway you have only provides voip via FXS and FXO ports (analog connections) when used in conjunction with a service provider that provides you this feature.
If you are set on using you 7942 phone you will need to do at least 3 things:
1. Buy a power supply or POE switch to power it. http://www.google.com/products?q=4%20port%20poe
2. Find out if it has SIP firmware on it now and if not, research how to aquire and load it.  http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
3. Configure it to work with a SIP provider or build your own SIP gateway of some sort.  http://www.google.com/search?q=sip+service+providers or http://www.google.com/search?q=asterisk
Good luck.
Brandon
-- please remember to rate and mark answered helpful posts --
Hall of Fame Super Gold
As always by Brandon, a great answer above, rated.
Hello Brandon,
Thank you very much for your help.   I will try your solution and come back to you for the results.
Cheers,
Ricky
Hello Brandon,
I have checked online for POE switch and they are exceeding beyond my expectations (e.g. they have too many ports as only 2 - 4 users maximum will be using the ports, but I could not find any 4 ports POE switch.)  I wonder if it would work by using some sort of POE adapters for powering up the phone and then connect to the VoIP modem I mentioned earlier on the post.
Do you think it will be a possible solution as I am trying to reduce the cost involved?
Kind Regards,
Ricky
Just buy a cisco phone power adapter, aka "brick"
Like Paolo said, just buy a single power supply for one phone if you wish.  they should be around $25USD on ebay, etc.
I found plenty of 4 port POE switches around $100USD when I searched for "4 port POE" on Google.
Brandon
801
