Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VOIP phones with Linksys router
Hi all,
I have Rogers cable internet at home and with cable modem i have linksys router hooked. Now I want to use Cisco VOIP phone. My question is ,, can I use VOIP phone with linksys wireless router and how ? Thanks for your help..
Re: VOIP phones with Linksys router
VOIP phones have to be controlled by something to work.
You can by a Cisco router like an 1861 or UC520 and use it for CME.
Otherwise, you can download SIP firmware for the phone and try to register it to a SIP provider. You would need to find a SIP provider that would let you register the phone directly to it.
Otherwise you could set up a Unix box with Asterisks and configure that. You can do some google searching for Asterisks and your phone model and try to register it to Asterisks. For that to do anything you would need more than one phone so that you could call each other. You could then register your Asterisks to a SIP provider also.
Either way, you need some type of device to control the phone.
Hope that helps.
nick
Thanks Nick for help.
119
