A minimum of 2801 will do. With CCME you can connect directly the IP phones or the existing PBX for the migration, and a variety of data interfaces, like the dual-T1 that can be used for voice and data simultaneously. You will need PVDM2 DSP card to support all the simultanous conversation that you plan to have on the PRI.
