Si
Community Member
VoIP switch/Siemens Config
Im just after some information of whether ive configure my VoIP test network correctly. Im using 48Port POE 2960 and Siemens Openstage 15 phones.
Switch Config
lldp run
interface FastEthernet0/1
switchport access vlan 125
switchport mode access
switchport nonegotiate
switchport voice vlan 169
switchport port-security maximum 2
switchport port-security violation restrict
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust dscp
auto qos voip trust
spanning-tree portfast
service-policy input qospolicy
The DHCP Subnet, im using Opt 43 with the manufactures code + the VlanID all in hex.
This seems to work, but is this the best way of making VoIP work? Without the Hex sting, the VoIP phone will not work saying telephony down. It would be tidier to have all the config on the switch to get this to work. I have a test bed of around 100 phones at the moment.
Many thanks
S
1 ACCEPTED SOLUTION
Super Bronze
Config looks fine - you have a qos input policy AND mls qos trust dscp, one will override the other so pick one and stick with it.
Otherwise assuming your phones are correctly landing in vlan 169 you're fine.
It is common practice to run DHCP on a server so there's no problem with the config you have in that regard - you can typically run it on the switch but centralised admin by the folks who are already looking after DHCP for the data VLANs is the way forward.
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Si
Community Member
Thanks Harrison. Is it possible to use Lldp to tell the phone what tag to use instead of Opt43? Or is it best practise to use the current method.
I'm having a few issues of the pcs not dhcping via the phone a restart usually resolves this but not ideal on a larger scale
Si
Si
Community Member
Should add dhcp is via centralised servers
1761
