voip with hipath siemens 3800 and cisco router 2951
Hi all,
we have a projet with a Customer, we must must implement solution voip in theire structure, they have siemens hipath 3800 and i want to know if it work with Cisco 2951? if yes how? and there is a special configuration for this? and this solution support all features of voip ?
thanks for your attention.
Walid zahri
Check this link out:https:/
https://communities.cisco.com/thread/3314?tstart=0
Also, check this out, they talk about communication with call manager but not necessarily CME:
http://www.cisco.com/c/en/us/solutions/enterprise/interoperability-portal/networking_solutions_products_genericcontent0900aecd805b561d.html
Please rate useful posts.
Hi George Thomas,  i want to
Hi George Thomas,
i want to thank u for your help , i checked out those links and its really help. thanks.
Have you looked in the Cisco
Have you looked in the Cisco interoperability portal??
java
if this helps, please rate
www.cisco.com/go/pdi
hi jaime,  yes i cheked but i
hi jaime,
yes i cheked but i didnt found nothing with hipath3800. thank u for ur reply
Bronze
Hello, walidit01. Check this
Hello, walidit01.
Check this link (http://cs.co/9000qMpY) for interoperability updates for CUCM Express. Are you already working with any Cisco partner or vendor for your client project?
Let me know if you have other concerns or e-mail (adawa@cisco.com) me directly.
Kind regards.
hi adawa, with my pleasure ,
hi adawa, with my pleasure , i e-mail you with more explanation of my situation.
Thank a lot.
walid zahri
walid.it@outlook.com
if we use HG1500 ip card , it
if we use HG1500 ip card , it can be worked? or it must be a interoperability between hipath3800 and cisco 2951.
thnak for ur attention.
199
