08-02-2010 12:35 PM - edited 03-16-2019 12:02 AM
Is there a way to increase the volume of a call on 7900 series phones from the UC?
I have a customer that is complaining the the volume level is not loud enough after adjusting the volume to the max on their phones.
Mario
08-02-2010 12:48 PM
You need to explain if this is IP Phone to IP Phone or if from PSTN which interface it's coming from.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-02-2010 02:12 PM
Hi Java,
This is for both IP phone to IP phone and IP phone to PSTN.
Mario
08-04-2010 11:57 AM
That would be a no for ip-to-ip phone calls. The only causes for this that I could think of are a) the user is holding the handset several feet away from their mouth; b) they are whispering; or c) there is a bug in the firmware of the phone (unlikely).
As for IP-to-PSTN calls, you can amplify the volume using the input gain command on the voice-port in IOS.
08-04-2010 01:45 PM
Thanks Jonathon, I knew about the IP to PSTN, but it is with the IP to IP phones where they experience the most issue.
