Voxeo SIP Phone Calls dropping thru Siemens Hicom300 during silence
HEllo
We have a developer testing a new Voxeo XML app placing a call via SIP thru the router via ISDN to the HICOM and then to the PSTN. When there is silence on the line the call drops. Any ideas? thank you
Re: Voxeo SIP Phone Calls dropping thru Siemens Hicom300 during
Since you have given us absolutely no clue about the gateway platform, IOS versions, configs and detailed prpblem symptoms etc ... it's going to be hard to give a definitive answer, but assuming your application is working through an IOS gateway, the most common reason why calls drop after periods of silence is the recieve RTP or recieve RTCP timer expires after an extended period of silence, which means no RTP packets come into the gateway. As a result the router assumes the call has dropped and clears the call. You can extend these timers here -
CME-Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CME-Switch(config)#gateway
CME-Switch(config-gateway)#
CME-Switch(config-gateway)#media-inactivity-criteria ?
all Both RTP and RTCP for silence detection
rtcp Use RTCP for silence detection
rtp Use RTP stream for silence detection, this is default
CME-Switch(config-gateway)#timer ?
media-inactive (dsp based) configure media inactivity timer- available for
h323/sip only at this time
receive-rtcp (non-dsp based) configure media inactivity timer- available
for h323/sip only at this time
receive-rtp configure absolute RTP receive timer in seconds
Try setting these timers to see if they make a difference.
Hello
thanks pcameron - I tried all the settings and still the calls timeout. We are using an IOS based router and today we ran the T1 directly to the router and not the PBX and same issue- calls drop after 10-20 secs of silence. Here is a debug ccsip;
*Feb 6 19:09:19.030: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 156.132.20.200:5060;branch=z9hG4bKa3c18a18f7998c33dd65a5442705f
38a973b525628eafd8a8f975db41ac4a6ff5060,SIP/2.0/UDP 156.132.219.235:5070
To: <9120232XXXXXX>;tag=3EEA94-EEC
Date: Wed, 06 Feb 2008 19:09:14 GMT
Call-ID: 0-13ce-47aa02e6-6289df3-bb3-1b0b608
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
Allow-Events: telephone-event
Contact: <91202327XXXX>
Record-Route: <156.132.20.200:5060>
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 7318 5046 IN IP4 156.132.34.202
s=SIP Call
c=IN IP4 156.132.34.202
t=0 0
m=audio 17336 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Paste a copy of the SH RUN and SH VER from the router, then enabled 'debug ccsip messages ' and 'debug isdn q931'. Make a single test call (too hard to follow if multiple calls happening) that shows the problem, and paste the logs here.
I am replying again as the first did not post. Here is the information you requested - thanks again. BTW our helpdesk is using the same router/pbx on a SIP/VOIP system with no problems...
274
